Introduction: Recycled Multimeter Test Leads
In this instructable I will show you how to recycle old rca cables in order to replace your missing or broken test leads.
Step 1: Preparing Rca Cable
simply straighten out the outer metal tabs until the cable is able to slide into where the test leads connect.
Step 2: Plug in Cable
Once the tabs are straight simply insert your new test lead
Step 3: Adding Accessories
You can use the test lead as is or cut and solder the probe end. You can also attach alligator clips or solder on a replacement probe... anything you want really.
