Introduction: Simple Lighter Trick
for the inner pyromaniac in you! will keep you and your audience entertain for, well however long you stick to it.
things you will need:
2 hands (your own)
a lighter (any)
optional
axe
hairspray
other flammable sprays
water
2 hands (your own)
a lighter (any)
optional
axe
hairspray
water
Step 1: Hold the Little Button Down
light your lighter.
blow it out
make a fist
stick the end of the lighter in your fist (the part that sprays gas)
blow it out
make a fist
Step 2: Patience!
the longer you hold the lighter in your hand the foosh you get at the end
Step 3: Light It
now pull the lighter out of your fist, light it, then put at the top of your fist. if you did it right it will light, but it won't burn. yet. once it starts to burn open your hand in a sweeping gesture. it should flare up and die.
Step 4: Variations
you can also do stuff like using axe, hairspray or other flammables as the fuel, but i normally use lighter fluid. you can also get your hand wet, spray it then light it. there is literly millions of combinations. experiment and find your favorite.
note: this is my first instructable, so dont go easy and yes i do know almost everyone knows this trick but for those who dont here it is. btw i am not responsible for what you do. and sorry i dont have my own camera yet
