Introduction: Stinger Blow Dart
this blow dart doesn't have a needle point, so it can be shot at living things and it won't hurt them that bad.
if you get hit in the eyes, i am not responsible for any injuries caused by this type of blow dart
Step 1: Supplies
you will need:
small screw
scissors
hot glue
tape
paper
pipe or tube(the gun itself)
small screw
scissors
hot glue
tape
paper
Step 2: Make the Dart
form the paper into a cone around the screw, then tap the paper.
Step 3: Glue
add glue via the back of the dart to secure the screw. the glue might get stuck to the sides before it get to the screw, so you can also take the screw out, put glue in the tip, and put the screw back in.
Step 4: Cut
put the dart in the end of you tube and cut as close as you can to it. check the fit and if you need to cut more off, do so. make sure you don't cut to much off.
Step 5: Done
you now have a finished blow dart that isn't skin penetrating.
