Introduction: Tactical Sling
how to create a tactical sling for under 15 euro
Step 1: Things You'll Need
you will need:
- 3 meters of 5 cm wide strap
- 2 meters of 2 cm wide elastic
- a right sized sliding buckle
- some thread (Black is adviced)
- a right size carabiner
- spare needles
- a sewing machine
- spare needles
- a sewing machine
Step 2: Sewing the Main Strap
cut the right size for you and make two of them.
sew them together (close to the edges) and make a kind of tube out of it.
Step 3: Puting the Elastic in It
pull the tube inside out. THIS CAN TAKE A WHILE!!
pull the elastic through the tube. it's easyer to use a rope.
Step 4: Make It Stretchy
pull the elastic 2 cm back in the tube and sew it right on the edge of the elastic.
strip up the tube to the wanted length and sew the other side of the tube (also leaving 2 cm).
Step 5: Attaching the Buckle
get a good length of the remaining strap and sew it on the ends of the tube.
Step 6: Finish It
get a little bit of strap and make a loop on the other side of the buckle (for the carabiner) and sew it close.
tada
tada
