Tattoo Machine Out of Household Material
Intro: Tattoo Machine Out of Household Material
build a prison style tattoo machine out of househeld items.
tools: needle nose pliers, knife, philips head screwdriver
parts: toothbrush, ball point pen, guitar string, mechanical pencil eraser, and electric motor from tape recorder
STEP 1: Find a Motor
i found mine in a tape recording machine. I heard that tape machine motors were the standard, but i have also heard of tattoo machines made of nintendo 64 rumble pack motors. When you find your motor, rip it out and take note of the positive and negative wires. Also rip off the stock gear attached to the motor crank. You will be replacing the stock gear with a mechanical pencil eraser fitted to the guitar string needle.
STEP 2: Make the Frame
I used a plastic tooth brush. First I cut off the head with the bristles. Then i melted a 90 degree angle in the top of the brush for the motor to rest on.
STEP 3: Cut Up a Pen for the Tube
find a normal ball point pen and take out the ink and the tip to use the shell for the tube of your needle. Get those guts out and then tape the tube to the outside of the toothbrush. Then connect the toothbrush frame to the motor so that the eraser gear hangs over the edge of the toothbrush. Take your guitar string and bend it in a 90degree angle. Then stick the angled string through the eraser stuck to the motor near an edge. Next cut the needle so that it only pokes through the tube when the motor is turned on.
STEP 4: Get Stoked, You're Done
I have my motor connected to a power source with alligator clips, but it would work better with a power foot switch . Connect it, dip it in ink and you're ready to go ruin lives.
50 Comments
Casper87420 4 years ago
ZainuM 5 years ago
LIZARDSGURL15 5 years ago
Froggie2942 7 years ago
MyiraS 7 years ago
Karma wangmo 7 years ago
bobankarstens 7 years ago
@veverica Umesto gumice koja ide na osovinu motora,uzmi jedno dugme i stavi osovinu u jednu rupu na dugmetu.Iglu stavi u rupu na suprotnoj strani dugmeta i voila!!!
@MUNCHINE > It's not f..king Spanish nor Bosnian,it's SERBIAN,capisch?!?
sresrose1206 14 years ago
i own airsoft 10 years ago
professionals dont take classes the most they would do i have had an apprenticeship or maybe taken art classes but there is no such thing as a tattoo certification for everywhere the most is to get certified to tattoo at one shop
BerinaSpliffta 12 years ago
invincible airsoft 12 years ago
naruto the ninja13 13 years ago
charles.david.sutherland 14 years ago
dsman195276 16 years ago
lane29 14 years ago
Eidolonmyst 15 years ago
dsman195276 15 years ago
eyerobot 14 years ago
The string is seated off center, On an eraser, Attached to a horizontally mounted motor shaft, Then bent downward towards the tube.
The off center movement of the guitar string forces it up and down.
Just in case someone else cant wrap their brain around how this thing works.
One question i dont see answered in any of these instructibles about tattoo machines is, How deep should the needle penetrate into the skin?
A minimum distance would do for a start position, As I realize skin has different thicknesses, But one setting for all skin types seems possible, And a far sight safer than eyeballing it.
I just dont like the idea of gouging someones muscles, Just to learn how far is too far.
dmwl 15 years ago
