Introduction: The Algae Experiment: How to Build Your Own Algae Photo-bioreactor.
In this instructable we will go over how to construct an at-home version of a photo-bioreactor which will use solar energy and artificial lighting with carbon dioxide to produce algae biomass.
The aim of this project is to create an model which harbors an ecosystem fit to help us escape a fossil fuel economy. We are in an era that is experiencing a shift from humanity trying to dominate nature, to then trying to preserve parts of nature and now trying to reach a reconciliation with nature. This is the algae experiment; an idea that is trying to move away from a linear wasteful and polluting way of using resources to a closed loop system where all resources are kept in a closed loop cycle.
Check it out working.
https://www.youtube.com/playlist?list=PL315E7074BE...
Follow the possibilities of harvesting algae for fuel & see the difficulties met along this journey on-line at
@@@: thealgaeexperiment.tumblr.com
a published paper on the subject can be found on
@@@: http://issuu.com/mouchmouch/docs/thealgaeexperime...
For more info or to get in touch you can reach me at
http://www.mouchmouch.com
Step 1: Shape, Size & Materiality
Step 2: The Ribs
I tried clear acrylic so as not detract from the function, which would be the algae tubes containing the algae. However. having to deal with all the transparencies of the materials made the model seem very confusing.
I needed each rib to consist of two pieces of wood in order to provide a stable ‘leg’ for each segment whilst I would be putting the model together but also to be able to withstand any rocking from pressure the model would experience during the cultivation hours. I ordered 50 M4 grub screws with a cup point and 150 M4 hexagon nuts and got started on the ribs. (M4 denotes the diameter of the screw; 4mm) I spaced the ribs apart 20mm which allowed them to be able to free stand. Together all 5 sets made a very sturdy model base.
Step 3: The Tubes
I initially wanted to use 15mm outer diameter tubes with an inner diameter of 12mm in order to carry the water required to grow the algae, as well as to match the pump power (4000 Liters per hour) that I had obtained for a previous model. However I quickly realized that at every return point of each tube there was no silicone or plastic based hose that was flexible enough to bend around to each connection point.
This wasn’t all disappointing as it meant that I could downsize to 12mm outer diameter tubes with an inner diameter of 8mm and save on cost at the same time. Unfortunately even though I moved down to that size, finding a hose which would fit on the outside of the 12mm seemed impossible.
That is when I decided to try to enter the 8mm inner area of the tube; something considered very unconventional and ‘inconvenient’ but to me this was the only option as far as flexibility was concerned with the materials available to me. I found a 8mm outer diameter silicone tube and it fit perfectly inside.
Step 4: How It Came Together
Although at first one pair of tubes seemed easy to connect to each other with the 8mm silicone hose, repeating the process 40 times with such a small radius and a tendency to buckle in and fold on itself seemed impractical. I therefore had to come up with a different system of transporting the algae from one tube to the next. This meant either re-designing the ribs to a much larger scale which would set each tube further apart or changing the tube to an even smaller size which would allow me to purchase an even thinner hose with more flexibility to achieve that goal.
I decided not to go with either, instead I changed the pattern of transport; rather than consecutively going from tube to tube, I would skip 3 tubes on one end and 2 on the other, 3 on one, 2 on the other and so on and so forth. This allowed me to stick with the same design & tubes which were already put together and get a much larger radius which would ensure that the hoses would not pop out of place because of the pressure or their internal positioning in the acrylic tubes
Step 5: The Plinth/base
I decided to make it 1m tall and allow 15cm for each side of the 1m tubes to have space for the turnaround of the hoses. The final dimensions of the plinth were 1m tall, 1,3m long by 0.3m wide.
As this was going to be both an exhibition piece and a University project I felt that there was a strong educational aspect to it. I wanted to somehow be able to tell the story of the algae with this model. I decided to make viewing holes on the rear side which would show the process much like the doughnut company Krispy Kreme has certain stores where the customers can see the production line of how the doughnuts are made from the dough to the glazing.
On these holes I would label what each component would do. Bio-reactor, CO2 pump, air intake, light source. Once deciding on the location of these objects, I decided that rather than having separate holes with separate names, it would be better to have one panel which would be seen as one object containing all the information one needs to know which would be far less distracting.
This turned out to be a really good choice after all and the laser cutting machine did an excellent job. Etching turned out to be much harder than I thought as every letter had to be converted to an object which meant that there was a much higher chance for an error to occur. Each letter had to be checked and cleared of any unwanted lines as well as check for disconnections in the comprising lines.
Step 6: Colour
Step 7: Sealing the Bio-reactor
When trying to fit each hose in the tubes it was extremely hard to get each one in at first. To solve the problem I countersunk all the tubes in order to get a ‘start’ in each hose so that it could slide in with ease. This was an excellent solution as later I poured glue on the countersunk tube with the hose in place which created a lake which would seal shut. Result: not a single connection out of the 40 connections leaked.
Because the tube was a very small space with a limited air supply, the instant glue would not dry instantly, this created a small puddle inside each connection. I therefore had to try various positions every 5~7 minutes to ensure that each connection would seal on all 360o.
Step 8: Hose Fitting
The adjustable handle also meant that I could regulate the speed at which the algae would travel round the model and effectively either accelerate or decelerate the growth when needed.
Whilst I would be transporting the model, I would like to have the ability to separate the bio-reactor from the plynth. I used some heavy duty clip-on clip-off fittings which allowed me to completely disconnect the bio-reactor without compromising any connection points.
Step 9: Test Runs
Step 10: Growing the Initial Algae Culture Pt I
I then proceeded to continue to grow that culture until I eventually reached the required 5.5 Liters after approximately 2 weeks. The algae was growing exponentially quicker due to the limited bottle room I would provide along with excellent sun exposure and feeding regime.
Step 11: Growing the Initial Algae Culture Pt II
Step 12: Test Runs
Perhaps it was the location of the model posistioned against a window which received very good sunlight both artificial and genuine but it had grown at a steady pace becoming greener every day.
Step 13: Outcome
I will keep you posted through my tumblr blog
http://thealgaeexperiment.tumblr.com/
where any publications results and other events that will be organised shall be posted.
Thank you for looking through this instructable and please contact me if you need any further info.
Charles
