The Ultimate Fog Machine
Intro: The Ultimate Fog Machine
this instructable will show you how to make a the ultimate fog machine .and also show you the fog chiller designs i tried even though they did not work for my fogger
STEP 1: What You Need
you don't need much to make the ultimate fogger .in fact you only need four things
-mosquito fogger
-small propane tank (type used for pipe soldering)
-mineral oil (food grade i.e. laxative)
-lighter
-mosquito fogger
-lighter
STEP 2: Fog It Up
this step is rather simple too (as the best things in life are)
.all you need to do is put the mineral oil in the mosquito fogger
.connect the propane tank .light the fogger
.let it warm up
.pull the trigger and make thick white fog
.let it warm up
STEP 3: Safety and Such
ok ok .i know some of you out there are thinking this is a terrible idea .and yes heating mineral oil to the point it smokes is a bit dangerous not to mention flammable .and i did manage to catch my rig on fire while trying to chill the fog .it was a few tense moments but I kept my cool .turned off the propane supply and the fire burned it self out rather quickly .anyhow you shouldn't use it around open flames .that is even on the safety instructions on the fogger it's self .another thing you should not do is use any poisons in the fogger you intend to use to make fog .nor should you use an old fogger that was used for fogging poison
.i would NOT recommend using this inside .the fog isn't the best of things to breath but i would say its less harmful then smoking cigarettes .if for what ever dumbass reason you do use this inside you need to have a fan or three ready to clear out the smoke
i was using my fogger to see how the air moved around on our back porch .trying to figure out how to most effectively cool it and while doing so i the smoke had blown around my house and across the street leaving a hazy trail .i walked out the front door of my house and the neighbor from across the street was already on his way over to see if every thing was alright .i had to explain how i was just using my fogger
.the point of that story was that by using this fogger there is a good chance you might get the fire department called out .so using it will be done at your own risk
STEP 4: Fog Chiller How Not to :first Attempt
i looked around on here before i attempted making a fog chiller of my own .and the three fog chillers i found were the way to go .and you should see links to those in the related instructables area at the upper right part of this page
what i did to make my first chiller was
.get some 3/8" copper piping
.coiled it around the propane bottle
.got a container to place the coil and ice in
.and made a small clamp out of a wire to hold the tip of the fogger to the coil
howd it fail? .well it did and didn't fail .i used regular ice to begin with and it worked semi ok .the fog was cool but failed to drop to ground like i wanted .so to try to cool the fog mow i added a salt water slurry .the salt water not freezing at 32F was much much colder and the water made for greater contact with the pipe for heat exchanging .i thought the possibility of the fog condensing and turning back to its liquid state was a possibility but if you don't fail, you fail to learn so thats exactly what happened .i learned that the colder water did make the fog turn back to oil and whats more clogged the pipe leaving no room for the fog to easily pass threw .so a little pressure built up and pushed out the connection point of the fogger and pipe .oil and fog were both coming out and shortly after the fire i previously typed of occurred
STEP 5: Fog Chiller How Not to :second (more Successful) Attempt
for this second attempt what i did was first gathered my materials
.an ice chest
.old vacuum cleaner hose (5 feet in length)
.copper pipe coil i used in my first attempt
the to assemble it what i did was
.coiled the vacuum cleaner hose in the bottom of the ice chest
.taped the hose in place on the top of the ice chest
.placed the end of the copper pipe into the vacuum cleaner hose
.filled the ice chest with ice
this was more successful then the first attempt because the fog did come out of the hose and sunk to the ground .however where it failed in design was again the condensation of the fog on the inside of the copper pipe .though no fire occurred this time .it did spit out hot oil .i could have taken off the copper pipe and aimed the fogger directly into the vacuum hose and gotten my desired effect .though a fog chiller that works that was has already been made and again a link should be found in the related box on the upper right side of this page .if you can not find it there try using the search box (also in the upper right part of the page) and type in "fog chiller"
.an ice chest
STEP 6: Conclusion
my conclusion is that if you want to make massive amounts of fog for whatever (legal) reason this is the way to go .you're not limited by power cords .this fogger could easily fill a large arena with smoke so thick you can't see you're hand in front of your face using only about 5fl oz of mineral oil if you combine this with a fog chiller you will get the best and most ground hugging fog effect you've seen outside of a hollywood movie .which this is the type of fog and fog machine the most hollywood movies use
i hope you enjoyed my third instructable and put it to good (legal) use .and as always .constructive criticism welcomed
28 Comments
EngrMahmood 11 months ago
buntys 8 years ago
buntys 8 years ago
smooney2 9 years ago
I"ll stick with mine. with that smoke your just shooing them off not killing them. I use BVA oil and Evelore 30/30
Vulcanator 14 years ago
somebullcrap 14 years ago
IX Smith XI 14 years ago
ilpug 12 years ago
Aron313 12 years ago
ilpug 12 years ago
dfwsupergeek 13 years ago
Owenmon 15 years ago
somebullcrap 15 years ago
ilpug 12 years ago
sueman2 13 years ago
MadBricoleur 14 years ago
knex_mepalm 14 years ago
Owenmon 14 years ago
