Introduction: Tweeting Arduino Alarm With One PIR Sensor. Aka AlarmIno
Hi today I will be showing you how to make a tweeting Arduino alarm with a PIR sensor.
You will need:
- A parallax PIR sensor 3 pin
- Ethernet cable
- Ethernet shield (i use this one)
- Breadboard
- Arduino UNO
- 6 jumper wires
Step 1: Wiring the Thing Up!
- First you'll need to attach the ethernet shield to Arduino.
- Attach the PIR sensor to the breadboard.
- Wire up the PIR. ( gnd goes to -, vcc or anything like that goes to +, out goes to pin 7)
- Attach ethernet cable to seeeduino ethernet shield v 1.1.
Step 2: The Code
#if defined(ARDUINO) && ARDUINO > 18 // Arduino 0019 or later
#include <SPI.h>
#endif
#include <Ethernet.h>
//#include <EthernetDNS.h> Only needed in Arduino 0022 or earlier
#include <Twitter.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = {<<<a open ip here>>>};
// get your token from http://arduino-tweet.appspot.com
Twitter twitter("<<<token goes here>>>");
int alarm = 7;
int lever = 6;
int greenLED = 4;
void setup()
delay(1000);
Ethernet.begin(mac, ip);
Serial.begin(9600);
pinMode(alarm, INPUT);
pinMode(lever, INPUT);
pinMode(greenLED, OUTPUT);
void loop() {
if (alarm == HIGH)
twitter.post("alarm activated");
else
digitalWrite(greenLED, HIGH);
#include <SPI.h>
#endif
int alarm = 7;
int lever = 6;
int greenLED = 4;
void setup()
delay(1000);
Serial.begin(9600);
void loop() {
if (alarm == HIGH)
else
