Introduction: Usb Charging Riser Card
in this instructable i will be showing you how to make a riser card for your computer that will not take up any valuble slots or morts on the motherboard. (most but not all cases seem to alow spots for cards where there is no slot for it)
parts
you will need a riser card from an old AT system.
a molex conector (from a crashed drive, fan power connectors, electronics store
5 inches of 24-22 AWG wire.
tools
solder iron, scisors, wires striper, needle nose
Step 1: Setup the Card
Step 2: Prep the Connector
if using a board mounted socket solder the wires you previusly atached to the board to the socket. + connects to + 5volts. (if you need to find witch one is 5 v plug the male plug ito it find the pin that lines up to the red wire when inserted corctly) - conects to either of the center or both.
Step 3: Finishing
install the card preferably in a slot with no motherboard conector. conect a power conector to it. clase ths system up. plug in usb charge cables. turn the system on conect your divice and charging begins.
not responsible for anything that hapins resulting from use or misuse of this divice!
