Introduction: Using Artmoney to Hack Games
learn how to hack games using the memory scanner artmoney in this instructable.
Step 1: Download It and Open Minesweeper
first download the 7.22 freeware version of artmoney from this link and open minesweeper from the game file in the programs list.(the games file isn't in the picture).
Step 2: Learn the Basics of Artmoney
1.the search button used to search for values.
2.the filter button used to filter the searched values.
3.the process bar used to select the program that you want to hack.
4.use this button to transfer values to the list.
5.use this to clear the list.
Directions
Use button number 3 and select "winmine".
Then ready to hack!!!
Directions
Step 3: Time to Hack
go to artmoney and search for the value ten(this amount of flags left)(search box should look like the pic.)and click "ok".now i'll explain what he buttons do.
1.experiment with this one
2.enter the value that you want to search for here
3.enter the type of value here
4.personally i have never found this useful
Step 4: Filter You Results
first alt-tab to minesweeper and right click to drop a flag.
now in artmoney click the filter button and make the box look like this(look at pic.)again i will explain what the buttons do.
1.search type
2.filter value
3.values filter type
Now click "OK"
1.search type
2.filter value
Now click "OK"
Step 5: Find the Value
after the filtering you should have only one value left now click the red arrow to transfer the value to the list
Step 6: Changing the Value
now change the value to 10 and freeze it
sadly this will not help you win the game so now comes a cheat that will.
Step 7: Next Cheat
first search for a unkown intial value or unknown value
now in mine sweeper lose the game by hitting a mine.
now in artmoney filter for a changed value.
then start a new game in mine sweeper
in artmoney filter for the same as last time
also filter for the intiger type that is 4 bytes
repeat this process till you have one value
when i did it i got 1 when you havn't lossed yet and 16 when you have lossed
now lose the minesweeper and change your new value to 1 and freeze it
now play mine sweeper with a new game and lose and you should be able to click on boxes after you lost and once you click all the boxes you will win the game
Step 8: Final Thoughts
these are not the only hacks you can do
exaples
i have hacked the time in this game to so try and see if you can do that on your own.
and remeber you can hack almost everything that uses memory to store a value.
exaples
