Introduction: Valve Stem Hack! Possibly the Worlds Best?
Ok, this is a fairly simple one, BUT ive never seen anyone else do this, so without further adue, here it is: the worlds best valve stem hack !
concept: valve stems are generally, compatible with all air compressors and bicycle pumps, why not use them as a way to get compressed air into projects, like cannons and dart guns?
plus, valve stems are able to operate safely far beyond the regular pressure of a inner tube , and most importantly,THERE CHEAP! and sometimes free!
so lets get started!
Step 1: Materials and Tools
you will need the following,
a valve stem, either type will work, just the screw in is better / safer you can get these for fairly cheap, and oftentimes tire stores will give you one for free
a pipe fitting to mount the valve stem in that fits your project
vice
drill bits, one that has the same diameter as the rubber fitting on the valve stem, and a small one for a pilot hole.
a drill
knife and sharp-e
vice
a drill
knife and sharp-e
Step 2: Mark and Drill a Pilot Hole
next we will mark the middle of the pipe fitting and drill a pilot hole.
Step 3: Make the Hole Big
now use the closest matching drill bit you have to the diameter of the rubber gasket on the valve stem, and drill the hole into the fitting
Step 4: Clean Up the Hole
use your knife to trim away unwanted excess plastic
Step 5: Insert Gasket
take the gasket off of the valve stem and check to see if it will seat properly , you may have to use your knife to trim a little off the sides.
Step 6: Insert Valve Stem
insert the valve stem into the gasket and screw on the nut onto the other side, and tighten down till it wont budge. and your done!
