.vbs Timed Pop-up [Code Intended for Notepad.exe]
Intro: .vbs Timed Pop-up [Code Intended for Notepad.exe]
This Application enables you to open any document and program at a set time. You will be able to set how many minutes until your file is run.
This application will ask you:
1 - What file you would like to use as a Pop-up
2 - How long until Pop-up becomes enabled
3 - And if you are sure if you want to continue.
Answers expected for program:
1 - (Example) File.txt , Log.vbs , Chrome.exe , etc.
2 - Any positive number Example: 1 , 30 , 3 , 16 , 54 , 96 , etc. (A number represents one minute.)
3 - Yes , No
Key words to assist you:
- help
"help" Enables an automated response that states the options listed here and more.
- cancel
"cancel" Exits the application.
*Code intended for Notepad.exe
STEP 1: Pop-up Code
Dim w Dim x Dim y Dim z
set oShell = createobject("wscript.shell") Set sapi = Wscript.CreateObject("SAPI.SpVoice")
x = inputbox("Which file would you like to use as a Pop-up? Example: File.txt")
if x = "help" then sapi.speak "Type Cancel to exit." sapi.speak "Type Help for help." sapi.speak "For question two answer with a number." sapi.speak "Each number represents one minute." sapi.speak "Please re-open this application to try again." Wscript.Quit 1
else if x = "cancel" then Wscript.Quit 1
end if end if
y = inputbox("How long until Pop-up becomes enabled")
if y => 0 then z = 60 * y
else if y = "cancel" then Wscript.Quit 1
else if y = "help" then sapi.speak "Select a number for this question." sapi.speak "Each number represents one minute." sapi.speak "Type Cancel to exit." sapi.speak "Type Help for help." sapi.speak "Type yes or no for question 3" sapi.speak "Please re-open this application to try again." Wscript.Quit 1
else msgbox ("Character not valid") Wscript.Quit 1
end if end if end if
w = inputbox("Are you sure?")
if w = "yes" then msgbox("Thank you for using a Code by Allzweck Namen.") Wscript.sleep (1000*z) oShell.Run (x)
else if w = "cancel" then Wscript.Quit 1
else if w = "help" then sapi.speak "Please type yes or no for this question." sapi.speak "Type Cancel to exit." sapi.speak "Type Help for help." sapi.speak "Please re-open this application to try again." Wscript.Quit 1
else Wscript.Quit 1
STEP 2:
*Help for debugging may be available.
DIY Hacks and How Tos 8 years ago
Cool project.
