Introduction: Wooden Gear Clock
I have always loved wooden gear clocks. So for my birthday my wife gave me a Dremel and a copy of Scroll Saw Magazine that had a pattern for a wooden gear clock. This is my entry for the clock contest and 4th Epilog Challenge, it is also my first Instructable. So fair warned. I have had thoughts on making gear clocks to sell. If I had a Zing laser cutter then cutting out the gears would be much more precise and need much less sanding and fine tuning.
Step 1: Get a Pattern
My pattern came from Scroll saw magazine spring 2011 Issue 42. You don't have to get this one It just had a good pattern and instructions.
Step 2: Materials
The Materials needed:
Spray Adhesive
3/4" plywood
1/2" plywood
1/4" plywood
1/8" plywood (hard to find for me)
1/8" hardwood (I did not use this but probably should have)
1/4" washer
2 #8 2" wood screws
2 #8 washers
14' 50lb fishing line
1 1/2" 13 1/2 "copper pipe, end caps,
Safety gear (ear, eye, hands, body... ect) If you want it protected then protect it
1 1/2" 5" copper pipe, end caps
2 hooks
7lb led shot
1/16" rod or wire
1/8" brass rod
#8 threaded rod and nut
3/8" wood dowel
1 5/8" light compression spring
BBs
wood glue
Wood I got at big box stores, everything else Ace;
Tools
Dremel with router and wood bit (or scroll saw)
Dremel sand paper or sanding wheel (or belt sander)
cut off disks
hand drill (or drill press is better but did not have)
drill bits (3/8, 17/64, 1/4, 9/64, 1/8, 1/16)
Dremel engraving tool
Step 3: Cut and Glue
First make copy of the pattern, then make additional copies of parts that you must cut more then one of (such as wind pulley parts) the pattern only has one of each
Second cut out the pattern, if using the Dremel make sure there is a lot of extra wide border around each piece, the router guide will push up the paper destroying the pattern, which is bad.
Third, spray adhesive on the back of the pattern and attach them to the blanks.
Step 4: Drill Holes
Drill the holes in the patterns, sand the rough edges that the drilling makes, or the Dremel guide will get stuck on them.
Note, use an awl to mark/start hole then drill
Step 5: Cut Out Parts
Cut out the parts.
I recommend start with the non gear parts first to get used to the Dremel and get the speed setting right.
Also using the engraving tool, engrave the numbers on the gears, I also did not drill out all of the holes on the minute wheel I used the engraving tool to mark them instead.
Step 6: Sand Everything
As the title says, SAND EVERYTHING. Every edge. Then sand the gears, make sure the pinions (small gears) mesh properly with the proper gear.
Step 7: Glue the Pinions, Connectors, and Wheels
Glue the pinions, connectors, and wheels together, Also glue the wind pulley assemble together.
Sorry I did not take pictures of the glued pinions.
Step 8: Assemble It
Finally put it together.
Make the weights.
Following the blown out diagram, assemble the clock.
Make sure you string the wind pulley correctly
All that is left is to run the clock and adjust the pendulum and mounting to make sure it keeps even time.
Note: As you add each wheel, make sure the wheel and pinion mesh by running the wheel by turning the pinion, If it doesn't run smooth, make the gears that are binding and sand a little off. Make sure the wheels run smoothly.
I did not take off the paper to make it easier to see in the picture but I will.
Finalist in the
Clocks Challenge
39 Comments
Question 2 months ago
Buenos días ! Podemos hacer los engranajes por Autocad ! Pero me gustaría saber la cantidad de dientes de cada uno ! Un abrazo y muy buen trabajo !!!!
10 years ago on Introduction
I am building an entire clock 90 teeth on the largest gear....my own design
im in high school and i was looking or an easier way, you see i have all year to biuld it, but 618 teeth is alot! (90,8,64,12,16,40,10,48,(8,60 x5))
band-saw get them down to about 1/32" but then im on my own filing/sanding
i use a scroll saw but it slow work very slow...... jigsaw chips the Baltic birch to back
so i found a strip sand on the internet would work better i dont have this tool
i have all the tools i method at my disposal except a strip sander so please is there a power tool that will sand this for me,,, that i can buy under $100?
Reply 3 years ago
How about a disk and belt sander combo like this? https://www.amazon.com/WEN-6515T-Belt-Sander-Sanding/dp/B07KL4BQF5/ref=lp_552882_1_2?s=power-hand-tools&ie=UTF8&qid=1546557450&sr=1-2
Is this what you mean by a strip sander?
http://www.harborfreight.com/air-belt-sander-97055.html
I used the Dremel to rough out the gears then used a diamond grind/sanding wheel to finish cutting out /sanding the teeth. I have also thought about making a jig mounted on a scroll saw (if I had one). The jig would have a pin the gear could turn on and the pin would slide forward and back. The jig would allow you to cut one side of each gear, so slide the first tooth into the blade, slide back, rotate to next tooth, slide forward to cut.. ect Then turn the gear over to cut the other side of the gear. Not sure if this would work. The Scroll saw magazine cut each tooth with the saw then used a vertical belt sander to finish/sand each tooth. I am not sure what other tool you could use. The Dremel worked for me but yes it was labor intensive.
Can you please post the templates somehow? It's very hard to find a particular clock design online because there are so many variations. I'd like to see this one in particular.
Reply 3 years ago
You can actually order the single issue of the magazine.
I think copy right means "copy and sell" Not copy and giveaway. Just my thought!
I am sorry but I do not believe I can due to copyright. The template is property of the magazine.
ummmm, sooo they invented the clock?
the idea here is to share on how to.
and if you are still not for it
do your own template, or a bit of numbers.
I don't think he can post those because of copyright but you can recreate the templates with Matthias Wandel 's gear template maker: http://woodgears.ca/gear_cutting/template.html the free one should work but the full version has a bit of a hefty in price. . .
Thanks
I can probably work out the gears myself in CAD but that pendulum mechanism I'm not so comfortable with
Second Mathias' site- he has some serious wood gear guidance.
Question 4 years ago on Step 8
So, do I understand correctly that you cut all your gears with only a Dremel? No scroll saw or band saw? Looking forward to your response. I'm in the layout and practice-gear portion of making my first clock now. Thanks!
Hi. I don´t know much about making clocks or gears, but I have been looking into the subject lately and found interesting stuff on Internet. Just keep searching, there is a lot of stuff on the Net ...
I found out that four of the basic (and more important gears) that you need for a clock are the 8:28 and 7:24 (teeth each). You can print the gears using this online tool
https://woodgears.ca/gear_cutting/template.html
and a copy of the template is... ?
(please) :D
i would post this in the laser challenge, you might win a laser printer which would make this much easier. this is also a great i dea, I just need to find the diagrams...
10 years ago on Step 8
Unfortunately, not much to learn here
You should explain a least how to properly cut the gears...
Poor instructable (but nice job ;) )
same. i'm about to make one but i dont know how to cut the wood gears..and what to use so that they can rotate without friction...
nerick, Yes I didn't know where copyrights started/ended so I just tried to paint with broad strokes. But how I cut the gears was to follow the outline of the template with the Dremel and stop before the Dremel cut to far into the gear (due to dremel thickness) then I took sanding wheels and finished shaping the gears. The pic I used shows the 'm' shape that I used to rough cut the gears.
juanvi, You can ether use a Dremel (harder) or a scroll saw. I used contact spray glue to glue down the template onto the wood then cut around the lines, then lots and lots and lots of sanding to make the gears mesh correctly allowing them to turn without binding.
