Wooden Kneeling Chair
Intro: Wooden Kneeling Chair
A kneeling chair is what you need if you have to pass a lot of time in your office.
Unfortunately this type of chairs is quite expensive and not very common. This is one reason to make your own kneeling chair, which will also make you very proud.
STEP 1: References
If you surf the web looking for "kneeling chair" you will find a lot of references. There are different chair types and I chose the one which inspired me.
STEP 2: Parts and Dimensions
The making of this chair is quite simple. Just look at the image to have right dimensions of every part. Cut wood bars and panels. You will need also two more thin panels with same shape and dimensions of these ones, since I updated the cushion making.
STEP 3: 3D Views
Here you can see some views of the 3D model, with no cushion and wheels. This will help you to place parts together.
STEP 4: Building Process
After cutting all parts with right lengths and angles and drilling holes, place parts one adjacent to the other, in the right sequence. Then insert two long dowels in the holes to check assembly. I also added some temporary wood bars to fill empty areas.
If everything fits you can glue some bars together. Look at the previous drawings to well understand which ones.
STEP 5: Set Up for Dowels
The most important connections, the ones between diagonal bars and horizontal wheel supports, are made with two dowels and a screw each one, as you can see in second picture. To connect wood plates to structure you can also use only screws, which will be hide by the cushion.
Drill all holes for dowels, add glue, insert dowels, place parts together and tight them with screws.
STEP 6: Kneel Cushion Board
I used glue and screws to connect the kneel cushion support to the diagonal bars.
STEP 7: Seat Cushion Board
Here is the seat wood boards. Use the same technique as for the other plate.
Screws here are quite useful since surfaces are not parallel and using clamps is not simple.
STEP 8: Connect Parts
While glue is drying you can connect parts together with a big dowel or metal bolt.
STEP 9: Check and Finish Structure
Now use sand paper to finish surfaces and as some finishing paint as shellac or impregnating agent.
STEP 10: Set Up Cushions
Here you can see that I was going to glue foam rubber to structure boards. Actually I then decided to glue rubber to additional plates so to hide fabric between two surfaces.
STEP 11: Foam Rubber
As you can see I used different foam types. The black one is harder, and will avoid that kneels touch the board. Other two types are softer and they will keep fabric tense.
Remember that I glued foam rubber to additional plates, these pictures are not updated.
STEP 12: Cushions Ready
Add an elastic fabric over the foam and pull it below the plate, them fast it with a staple gun. Then glue the new plates on the structure boards.
STEP 13: Wheels
I had these wheels but you can use different types. I suggest swinging wheels because they will help you moving on the chair. Wheel brakes are not useful.
Mark horizontal surfaces with a long rod when chair is open in extended or middle position. Then cut away those four pieces and screw wheels in place.
STEP 14: Ready to Sit
Well done, kneeling chair is now ready. Time to test it at your desk. You also can close it and hanging it on the wall when unused.
65 Comments
volandron77 2 years ago
andrea biffi 2 years ago
https://photos.app.goo.gl/cT3kayeQgWZDjVEK8
https://photos.app.goo.gl/wDrP8HeQcTCS9zPR7
arfalathwen 2 years ago
juanmiandav 3 years ago
andrea biffi 3 years ago
Aafke-Art 3 years ago
I love this chair! Great project and design, can't wait to make my own!
HetoN 3 years ago
Of course changing length of seats from 310mm and 370mm to over 400mm will make more comfort in using.
To newone who could try this project - be care, and make any check the measurement!
Good luck!
SDSB 3 years ago
apchar 3 years ago
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<Error>
<Code>AccessDenied</Code>
<Message>Access Denied</Message>
<RequestId>B41D9253268213AE</RequestId>
<HostId>
fuoiL/8Zgm2a+MIQ6OGaC0uquQZmPRYRPnUiIOWzwn3jZRSKJYwCvbI2HlR9RKsMEwmutuGXfpI=
</HostId>
</Error>
ahudrey18 3 years ago
La imagen de las medidas sale borrosa, podría compartir la imagen que se pueda leer las medidas
jorgebarnes 3 years ago
pastorulero 4 years ago
pedroriveraromano 4 years ago
The "C" shape of the Knee pad is not necessary, cutting the extra protrusions the chair is more confortable.
As soon as I finish painting the wood I will try to upload pictures.
Great design!
andrea biffi 4 years ago
I'm so happy you made it!!
LeandroT19 6 years ago
Hi! Nice work!!! Can you upload the sketchUp file? thanks
andrea biffi 5 years ago
