Introduction: Working K-nex Grenade With Pin!
this thing is double the size of others, so more shrapnel will fly out. the only problem is when building you have to be careful or the grenade will fall apart. if this is similar to someone elses I am sorry.
Step 1: Get Your Pieces!
in this photo I have only 1 rubber band. you need 2 instead of 1. you need:
8 green connectors
3 snowflake connectors
24 yellow half moon connectors
8 red connectors
2 gray single slot connectors
1 gray rod
4 gray spacers
4 blue spacers
2 rubber bands
8 green connectors
8 red connectors
1 gray rod
4 gray spacers
4 blue spacers
2 rubber bands
Step 2: The Bottom
this is the bottom of the grenade. you need:
8 red connectors
1 snowflake connector
8 red connectors
Step 3: The Bottom Body
this is the bottom body of the grenade. you need:
8 yellow half moon connectors
Step 4: Body Connecter
this here piece connects the bodies of the grenade. you need:
8 yellow half moon connectors (I here used gray)
Step 5: Upper Body
this is the upper part of the body of the grenade. you need:
Step 6: Top
this is the top part of the grenade. you need:
8 green connectors
8 green connectors
Step 7: Pin
this is the pin that allows the explosion by this grenade. you need:
1 gray rod
4 gray spacers
4 blue spacers
1 gray rod
4 gray spacers
4 blue spacers
Step 8: Add Rubber Bands
BE CAREFUL WHILE DOING THIS STEP! A SLIGHT MISTAKE CAN HAVE EXPLOSIVE RESULTS!
put the rubber bands so a large detonation is made. you need:
2 rubber bands
2 rubber bands
Step 9: YOUR DONE!!!!!
thank you for making my instructible PLEASE SUBSCRIBE!!!!!
