I hope I can make this instructable easy enough for all of you to try it.
I needed a lot of patience to make this lamp but the results are worth it. I can't tell you enough how rewarding it is! :)
Remove these ads by
Signing UpStep 1:
I can't tell exactly how many you need because it depends very much on how thick your strips are but you can make some now and some later.
To obtain the effect of this lamp, you need corrugated fiberboard.
Visit Our Store »
Go Pro Today »
What's wrong with the other angles?
So whenever we have guests over and I break out the lamp, I made sure to put it in such a way that only the corners can be viewed.
You should precise that people should make always the same pattern for a "big square". If they don't, some strips of different squares will be lined up when you make the cube (like on my picture) and it won't be pretty! Keep up the good work :)
And you are right about the pattern, I am sorry I didn't mention that in my instructable, I am going to edit it now!
It also penetrates the cardboard and leaves it much stronger.
I love working with cardboard. great idea
uncle frogy
