This instructables is about how to make video projector shelf that is cheap and reliable, but also stylish.
The basic idea to this is i do not use any money to make these instructables i have, i only use whatever i find and allready have or i got for free. for this project i used about 5$ to the "golden" chain (and because it can handle over 15 kilos of weight so the projector is safe from falling).
Tools needed for the job:
Power drill and some drill bits
screwdriver
sharp knife
wire strippers
and a hair dryer. You know, just to look fabulous.
Stuff needed:
Good and sturdy shelf
4 angle brackets
Enoug chain
And if you want some tape or paint.
So enjoy, comment and rate!
Step 1: Desing of the shelf
There is few criteria if you want to do somehting like this like i did:
1. It has to be right size, meaning that the projector has to fit in the closet and to the closet door. Also there has to be enough room for the cables.
2. The hinges(pic.5) has to be strong enough to support the weight of the projector so that is safe for you and the projector AND most of all to the children. If something like this hits you or someone to the head, it could kill. And besides the projector would not project anymore.
3. !!DO NOT use a shelf that is allready rotting or about to. Use only shelf that only has healthy woor or it is made from steel. The rotting wood isn't strong enough to hold for long.
Step 2: Installing the angle brackets and making hole for the cables
If using wood drill holes to the screws so the screws wont tear the wood apart. Remember this allways when using screws.
I had these angels for me a long time ago. so basicly they didn't cost me anything.
I used four angle brackets, two to the each side so the shelf woud be supported evenly when hanging on the wall and it would stay on the wall. I have plasterboard walls so it is a pain to get something stay on the wall because the plasterboard is wery fragile and it wont hold anything whitout good support and some anchor bolts
If you make the hole to the side or on top of the shelf use good tools, as you can see i did not have such(pic.3) ... But if you are like me....too busy to buy proper tools for the job or don't have big hole drill.(as big as you need) You can allways drill small holes and then just give it a good smak with a hammer, and you have the hole for the wires. but warning....it wont be pretty to look at...
Step 3: Installing the other nuts and bolts
Now its time to pre-install the video projector to the shelf and the chain.
The basic idea with the chain is that it supports the weight of the projetor when the lid is open for the projector. If the chain is not used the hinges will break in a couble of days and you know what happens then. Yes you are right, the old VGA projector will become 3D HD projector for sure...
So. Install the Chain first. The chain could be any color or shape you like but it should be able to hold 10 or more kilos in straight pulling weight. just to be sure not to enjoy FullHD 3D picture instead of VGA.
Drill two holes to the actual case of the shelf and to the lid of the shelf like in the picture 3-4 and then install the chain between the lid and the case. one to the each side so it will look like in picture 5. use wire cutters to cut the chain.(hint. leave few extra loops to the chains lengh after measuring so that you have the possibility to adjust the lenght afterwards for longer and for shorter lenght.)
Step 4: Insalling the projector
I had the simplest idea to mount the projector to the shelf, it had to be light and adjustable to side to side and up and down, And the projector has to be easily removed and make the cable installation easy and clean. simple.
And you know what. It is! Just cut a few inches of flat iron strip that has screw holes and you are done. After that install them to the bottom of the projector. (pic 2.) In to the bottom of the projectors back panel install screw that fits in to it so you can adjust the up and down angle of the projector.(this can also be done whit the shelf lid by adjustin the chains lenght.)
When that is done. drill holes to the lid and install the projector and thats done. just make sure that the projector is installed about center of the lid and the basic line is that it has to be straight and the flat iron has to point left and right in 90 decree angle so that the projectors movement is the same to the each side.
then comes the time to test the lid operating with the projector. picture 4 and 5 will tell the tale
If done right the projector will not chance its possition after closing and opening the lid few times. If it moves or slides down etc. check that everything is tightened propely.
Step 5: Remove everyhting and clean the shelf
Step 6: Apply the CARBON (tape..)
After cleaning make sure there is no bumbs or damps you don't want there to be. Believe me. They will show up from under the tape or paint if you are painting it.
With this i suggest that you use a normal hair dryer to make the tape more flexiple for the installation and to make the details of the shelf if it has got any. My goal was that the lid would be flat but the tape fell to the carving that is there and i just had to do it. Didn't have enough tape to make new one. So remember. The tape is made from plastic and plastic is flexiple if heated.
Also get a sharp knive for this to cut the tape and if there is any air bubbles you can make those disapear. Just make small cut to the air bubble and apply some heat and press it with finger and it will disapear. (pic4 and 5)
Step 7: Install the nuts and bolts back and add the details and projector
To make the wall mounting as easy as possible and safe. DO NOT install the projector to the shelf when istalling it to the wall. Do it after installing cables.
Step 8: Ready, Set, Action!
The projector in the last 3 pictures is installed on the lid. It is still missing cables in the picture, so make sure that the cables fit in there and prepare them before installing projector. Trust me, it will be 100 times easier that way.
Thanks for reading or waching the pictures. If you like this comment and rate! Any questions will be answered. And if you find some spelling errors please notify, since my language is not english or anything near that there might be some spelling error or "wrong" word for the purpose.
Good night from Finland, As clock is here five minutes past midnight.
Visit Our Store »
Go Pro Today »
1) la catena l'avrei messa all'interno che non si vedeva;
2) idem per gli attacchi a muro
Buon W.E.
kiitos kommentistasi, kirjoitathan jatkossa englanniksi kommenttisi. voit halutessasi käyttää google translatea.
thanks for posting, please write your comments in English in the future. you may want to use Google Translate.
Ps. I dont speak English also.
I have to admit that yours looks much better!
I couldn't agree more!
But, I'm thinking in tuning you can do and is about placing the angle brackets inside the shelf. I do not know if it's possible, but surely it looks better...
It might be nice to make a range of shelves/cabinets on the wall to hold DVD's etc with this hidden amongst them, may I'll use your idea in my own cinema room :-)
Great idea, Phil.
But, not only the the golden chain could have been on the inside but I would have preferred just 4 screws on the 4 corners inside in addition of the angle brackets,.
This is a good way to make a cheap video projector wall mount that will serve a long time.
