3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Plug-In Hybrid Car
This Instructable shows how I built a Plug-In Hybrid Vehicle.
A plug-in hybrid is a car which can run off a combination of electricity (stored in batteries) charged from a wall outlet, and some other fuel, such as gasoline.
This vehicle uses ONLY the battery-electric system to start with, and has manual control over when the other energy source is used, in this case, a propane generator.
Using only electric power, and THEN switching to a hydrocarbon fuel only when needed, is sometimes also called a Range-Extended Electric Vehicle, or EREV.
Think of this car as a poor-man's Chevy Volt or Plug-In Prius.
I already converted this Geo Metro to run on electricity. You can read all the details about that at my ELECTRIC CAR CONVERSION INSTRUCTABLE.
This Instructable will detail adding a second power source to the vehicle to extend its range.
I've been driving this car for about two years now as electric. The only thing I don't like about it is that I find that there are a few too many times where my destination is just a little outside my range, or there is no access to electricity at the destination to be able to recharge while I was there.
Adding the second power system to the car allows me to make trips that I would otherwise need to use a gasoline vehicle for.
In a nutshell - the generator makes AC electricity that powers the traction pack battery charger. The charger passes DC electricity into the batteries. By constantly "topping-off" the batteries, they are kept more full and allow the car to drive farther. The generator is NOT powerful enough to drive the car directly from. However, the generator can continue to run while the car isn't using any battery power, such as rolling downhill, or at a stop light.
So, the smaller, but steady power of the generator provides additional range, while the torque and energy of the electric motor and battery pack give the car good power for acceleration and hill climbing that the small generator engine would NOT be able to provide.
Also, engines running at a steady speed at fairly wide open throttle are MUCH more efficient than one running lightly loaded or at varying speeds (such as in a standard gasoline car.)
See more of my clean transportation projects at 300MPG.org
Step 1Tools and Materials
Tools and Materials
  • last photo ←
To get started, we'll need tools and materials for the project.
Also, this project involves AC and DC electricity, Batteries, Generators, Flammable Fuels, Welding, and Power Tools. Always observe all safety precautions. Wear safety glasses, work gloves, and ear protection. Never use tools or techniques you are not comfortable with.
Essentially, this is an electro-mechanical project.
For materials, we will need:
Electric Car
Generator
Circuit Breaker
Electric Outlet
Angle Iron and misc metal (check the scrap metal pile!)
Some plywood
Propane tank
Propane Primary and Demand Regulators
Propane hose, hose clamps, and threaded pipe
Muffler and pipe
Electric power cable (6 ga or thicker)
Heat Shrink and misc wiring connectors
12V relay
The Mechanic's manual for the car
3/8ths inch bolts, nuts, washers, lock washers, and threaded rod
For tools, we are going to need a bit of everything:
Wrenches
Ratchet and sockets
Wire Strippers
Crimper
Work Light
Drill & Bits
Screwdrivers
Battery Charger
Welder (although bolt-together construction would also work)
Tubing cutter, scissors, or knife
Clamps
Volt Meter
and assorted other home workshop tools.
I'm a pretty big fan of my Craftsman Cordless Tool set. Two drills/screwdrivers, a work light, a reciprocating saw, circular saw, flashlight, and power stapler all run off the same interchangeable batteries.  I have two chargers and four batteries.
It's great to always have the right tool handy and not have to trip on an extension cord!
141 comments
1-40 of 141next »
Aug 30, 2011. 1:00 PMtootall1121 says:
Henry Ford's original idea was an electric car, but Edison recommended he not do that, with the technology available at that time. The model T's were made so that they could also run on alcohol, since at that time having a still was legal and there were a hell of a lot more of those around than gas stations. The Chevy Volt is doomed to failure. The batteries that would make it work well were bought out by Chevron, and hidden away, even though Toyota had already started building all electric cars with those batteries with good results and reasonable range. The Volt, however only gets 100 miles at best, 40 to fifty miles at worst, and has no self recharging method. Seems to me, a solar panel on the roof and or trunk could recharge the car while people are at work, the major use of many vehicles. However, if the range might only be fifty miles, and many people commute farther than that, it won't do the job... it's also gutless and has a hell of a time with hills, while depleting the batteries faster. Tesla is on the right track, but their methods are still too expensive to be viable. They actually use bunches of laptop batteries.
As to the safety issue, so what? Life is a gamble. So what if a bunch of people get killed in such vehicles? That helps the planet by reducing the population... you won't see me in one, I think there are better alternatives. You can fuel a vehicle with almost anything that will burn, with a few modifications and installing a "smoker" pot. I've seen a truck that runs on wood chips, dry grass clippings, anything burnable.
Nov 1, 2011. 8:41 PMlove4pds says:
I am not a car person, so this could be a very stupid question. But why not put a fan in the front to help generate electricity as a turbine would, or even use the one that is on the inside for the water thingy (please don't make fun, cant think of the name of it), while driving to recharge the batteries?
Feb 20, 2012. 11:26 PMJ-Ri says:
Having a wind turbine on the front requires energy to turn. Even something small, like a radiator fan (is that the "water thingy" you mean?) in it's original location will use more energy to turn that you get out of it. I believe the best thing to do would be to completely seal off the grille area since very little cooling is required, or leave just enough to provide adequate cooling if heat is an issue.
May 8, 2012. 2:58 PMlove4pds says:
I meant as the car is driving using batteries the fan would spin from the wind of the moving of the car. So could that be the energy that moves the fan and charge the battery with that wind while using the battery or engine?
May 8, 2012. 10:27 PMJ-Ri says:
That's what I thought you meant. It takes more energy to turn the fan than you get from a generator it would turn.
May 9, 2012. 10:01 AMlove4pds says:
oh, got ya. i was thinking backwards.
May 9, 2012. 9:09 AMtootall1121 says:
Unless you're driving into a strong wind, yep, that would be the case. The odd thing I don't see any of the electric car makers doing is adding a few solar cells for charging the batteries while it's parked. Granted enough solar cells to run the thing constantly wouldn't be weight efficient nor would they work at night, but most people drive to work, or wherever, then the car sits outside in the sun all day. Even if the solar cells only gave back half the charge used to get to work, it would be worth doing. I think in the eight to twelve hours most people work, a couple of cells in the roof, hood, or deck lid would be able to charge it to full capacity. Why aren't they doing this? Seems like a Duh to me.
May 9, 2012. 9:10 PMJ-Ri says:
Even driving into a strong wind, you would be ahead by blocking any unnecessary air flow (such as through the grille) in an aerodynamic fashion (such as having a contoured piece of fiberglass or aluminum covering the opening)
You would never get anywhere near half the energy it took to drive to wherever you are parked with PV panels, even if you were parked there from sunrise to sunset and a panel the size of the entire car were pointed directly at the sun all day. As installed in a vehicle, you might have an average of 25% of the panel's rated output due to the angle the panels to the sun. This, of course, assumes that the drive is further than a person in decent health could pedal a bike without breaking a sweat. If you drive 2 blocks, you might get half the energy back, but it's still a small amount.
It would also add a few thousand dollars to the initial cost of the car, and due to the depreciation on a car, would be money thrown away. I doubt that anyone would keep the car long enough for a PV system to pay for itself.
Since it would be foolish to RELY on car-mounted PV panels to get you home from work, one would be much better off setting up a grid tie system at home and charging the car there at night. There, you would be able to have the panels pointed directly at the sun, and sell the energy to the utility company during the day for more money that it costs you at night. Those panels will still be there making you money after the car is gone, and there's no way a van can park next to your house and block the sun.
May 9, 2012. 6:31 PMtootall1121 says:
Au contraire, recent advancements have improved them a whole lot. Still, any extra charge would be an improvement over nothing, since most parking lots are not equipped with charging stations.
May 9, 2012. 8:51 PMJ-Ri says:
They have improved a lot, but it would still be impractical to use them to charge the traction battery, unless by recent you mean in the last month or two. Look at all the protection that is required for the high voltage wires, not for functionality, but for safety. If you had PV panels that were connected to put out the voltage to be able to charge the traction battery directly, they would have tons of insulation around them, and the cars would closely resemble the VW Thing with a roof probably about 4" thick and quite top heavy. If you have the panels arranged to output a low voltage, you would lose huge amounts of energy stepping it up to a voltage that could charge the traction battery. The panel would also be nearly horizontal, which at many times of the year and at most times of the day results in very little direct sun exposure due to the high angle of the panel relative to the sun.
May 10, 2012. 10:03 AMtootall1121 says:
I see you're not up on the latest tech. There are solar panels that are much like cloth now. Not much thicker or heavier than a good denim. I'm not sure of their output, but ANY help would be good. It doesn't take the output you think to charge the batteries some of these vehicles use. In fact, it's better to add charge slowly. Maybe the tech hasn't reached these car makers yet, or maybe it's still too pricey. Everything is when it's the new thing. one thing I have always wondered about, is that solar panels traditionally use the light alone for conversion There has to be some way to put the heat energy to use as well. Oh, by the way, why not enough of a solar panel to keep the battery of a normal car charged? That wouldn't take all that much, but would be a boon to people like me that have vehicles that sit for long periods of time between uses.
Aug 31, 2011. 12:28 AMtootall1121 says:
The version I saw the test of was battery only. A prototype, perhaps. Still, the powers that be want it to burn at least some gas, or other fuel they can charge you directly for. What I'm saying is that with the batteries that Chevron bought up, it wouldn't be required to have the gas engine at all, if one was to make sure the car was charged and or charging stations were widely available. If that charge was created by solar or wind power, then there would be no pollution from it at all, no use of non renewable resources. The biggest drawback to battery power without the lightweight, high output batteries is that the vehicle gets heavy having to tote common batteries around. Also, the current electric motors are still rather heavy, weight as we all know is the enemy of mileage. The advance that will change everything either hasn't happened yet, or has been hidden. You used to hear a lot about room temp superconductor research, but the last few years, I've heard nothing about it. Did it get invented then tucked away somewhere? We'll never know. It's actually possible to have a super miniaturized reactor that would power a vehicle pretty much forever, but try getting that past the regulators. Cold Fusion would make that even more likely, and fairly safe. Don't hear much about Cold Fusion these days either, hmmm.
May 8, 2012. 3:10 PMtootall1121 says:
to love4pds. Your idea is self defeating, the power it takes to propel the car is one thing, adding the required energy to propel fans is another, and self defeating. You can't take in more power than the fans would take away. That's one reason electric cars need to be as aerodynamic as possible, to create less drag, and hence take less power to propel. I think teaming an electric motor with a CVT transmission is the way to really go, it would certainly help on take offs, CVT stands for constantly variable transmission, or gears to put it simply. Thus a motor spinning at a given speed would be able to propel the car from a standing start to high speeds without the motor ever changing speeds. What would change is the amount of power required to maintain that speed, but the slicker it is, the better. It doesn't take all that much power to propel a car at a steady fifty miles an hour, but to get there takes torque, and when you go faster than that, the power requirements to do it go up exponentially.
Apr 30, 2012. 12:34 AMjeditanker72 says:
Kudos on an impressive project that I cannot even begin to comprehend. Electric cars aren't my thing, but I am glad there are guys like you out there thinking outside the box. One of you guys will be the next billionaire some day. I am only commenting because I saw all the negative stuff. Some people nit pick everything on here. The only safety thing I could see to anyone other than yourself would be to firemen. Maybe if you put a little hazmat placard on the back everyone would be happy.
Feb 20, 2012. 11:44 PMJ-Ri says:
Am I the only one that has noticed the wide-spread misspelling, wrong word usage and poor grammar in the posts that criticize by saying it isn't smart to do this? I love irony :)
Apr 27, 2012. 5:13 AMmsihcs says:
I have noticed that too, in particular the HHO guys do an amazing job of BUTCHERING the English language (I suppose we have to accept that, American English butchers every other language)
The funny thing that many people here seem to forget is what Taranach is basically saying, we all die at some point, there is no point in trying to avoid it. I agree with don't do things that are blatantly stupid, but if we do something like is shown here, in the end the world is better for it. Knowing that I am going to die makes me want to do something like Bennelson here is doing and leave this world a better place than the one that I live in.
Feb 17, 2012. 1:55 PMgoldbar2975 says:
How much is it per mile to run the generator?
Jan 5, 2012. 5:16 PMtrav997 says:
If i did this conversion with a truck and put batteries and propane in cargo area would this be legal?
Jan 9, 2011. 2:15 PMgrimdaddy says:
Your rig is very well designed and constructed. ...But You really need to think A LOT more about safety. Although propane tanks are relatively safe. The tank should either be better protected and/or centrally located in the vehicle. The best option would be an external mounting above the vehicle. The same goes for the combustion chamber as noted by other comments. Isolation is critical to passenger safety. To help you better understand my concern, please do a bit of research on the term BLEVE: Boiling Liquid Expanding Vapor Explosion. It is a nasty and very real possibility in the event of an accident. I have friends who are propane SFX guys and they have related some very scary stories concerning faulty equipment. Please be careful and seriously rethink a redesign for fuel tank protection.
Jan 10, 2011. 10:39 PMTaranach says:
OMG It Might be unsafe!!! People, living on the planet earth is inherently unsafe. Yes you try to make things as safe as possible but I am starting to get really tired of the alarmists squealing like a stuck pig on nearly EVERY instructible. The only way to be safe enough for these alarmists is to snuggle into a cocoon with purified water and intravenous feeding and never do ANY thing at all. Excuse me but life itself is a terminal occupation with risks around every corner. Minimize the risks as much as possible and don't do things that are blatantly stupid.
Many people are very correct that if these alarmist had gotten their way through the centuries we would NOT be living as we are today... Don't go outside the cave, you might get eaten! Don't stay inside the cave, it might collapse. Yeesh!!
Nov 27, 2011. 10:38 PMDIY-Guy says:
Taranach:
Don't forget the dangers of di-hydrogen monoxide (did I get that right?)
Heh heh heh!      ;)
Which part of the cave is the dangerous part again? Front (where the landslides hit one on the head with falling rocks if you venture outside), or the back where you can't dig out after a collapse?
BTW, I know a man who bought a car in the 1950's, converted it to propane and has been driving it ever since. He only wanted to buy one car in his lifetime and he's in his 80's now. The car has over 3 million miles on it and he just does basic maintenance, lube, oil, waxing, etc.
Jul 7, 2011. 8:51 AMLancasterPA says:
I'm old enough to have used metal monkey bars over concrete in my local parks and never had soft stuff to land in when on the swings with rusted chains. I used metal cap guns with out bright orange plugs in the end too. Putting a Propane cylinder made for a BBQ and not made to be carried inside a vehicle is just stupid dangerous to others. I don't care if this guy kills him self, it's just the kid next door does not deserve his home destroyed because this guy wants to experiment in a housing neighborhood. You can tell from the look that it is even an old cylinder. He does not even have a safety bar above the cylinder. That would protect the valve from being sheared off in an accident. That's not alarmist, it's a reasonable cheap precaution.
Jul 7, 2011. 7:15 PMTaranach says:
Considering that I have recently seen playgrounds with just such equipment does not mean anything as to your age... you could be 5 or 25... Point is moot.
As for the rest... pray tell, how do you get that propane tank from the place of purchase to your house? Do you carry it home by hand? No? Perhaps you use a cart or dolly? No? Then golly gee whiz you just put it into your car... and probably far less securely than this guy did... did he put the tank out on the front or rear bumper? No? Gee, it is reasonably protected.... point is also moot.
What about that kid who decides to smash a lighter against the ground with a hammer... does anyone deserve to lose their house from the resultant fireball? Nice appeal of "for the kids"... Point is moot.
Your "reasonable precautions" are just that... if you are so awesomely clever about how it should be done with "reasonable precautions" then Please post your own instructable to show us how to do it "properly.... until then... Point. Is. Moot.
Apr 30, 2012. 12:28 AMda winksta says:
you are moot. this setup is not safe. Taranach, all your Points Are Moot.
there needs to be a division between the generator/propane tank and the passengers compartment. For example look at how RV's have used and mounted tanks and generators for many years.
Apr 30, 2012. 8:38 AMTaranach says:
Been a while since I last looked at this one, had to refresh the memory... Yours is the first that makes any sense as to the "safety" aspect... You are correct that in the pictures there is no separation between tank, generator and passenger compartment, you are also right that it should be addressed... However, did you also notice that he plans to box it in at the end of the instructable? There have been no updates so can't tell if he did.
As to what I said and what I was specifically referencing? Really? Seriously? that is the best you can come up with?
Your point is not "alarmist", yours is precautionary considering what you are working with. I have no problem with that. Suggestions that are proactive and helpful are all good. The others were "alarmist" and negative and indicating that it should not be done at all.. My opinions were valid for the issues raised and statements made. I still stand by them. Yes, sometimes refinements need to be made for various reasons, including safety, and suggestions to make something better are also good, but to not do anything at all because it might be "unsafe" is ridiculous. We wouldn't have 90% of what we have today if nobody ever did anything "unsafe".
Did you also know that when locomotives were first introduced, they were restricted in how fast they could go because "traveling above 30 miles and hour" was deemed unsafe and even hazardous.Guess we should all go back to horse and buggy. No more "unsafe" cars!
Oct 28, 2011. 7:42 PMjaxofalltrades says:
wow..... o.O
Very cool,thank you for sharing!
Oct 28, 2011. 1:01 PMvov35 says:
So you don't have a mechanical conection between your gas engine and the wheels? Still quite an interesting project.
What I really want to see is a DIYer emulating toyota's "hybrid synergy drive"... that would be exciting news indeed.
Jan 9, 2011. 9:16 AMben2go says:
This is a cool conversion.However, it's not legal in any state.With a sealed generator compartment to protect occupants from explosion and a DOT approved tank,it will be half way there.The flooded lead acid batteries put off a gas while charging that is both toxic and explosive.I'm not flaming or degrading your project.In fact I really like it and it would be fabulous in a small pick up.I'm just not sure that you have all the information needed to make this a safe conversion.
Sep 16, 2011. 4:46 PMjpayton says:
Sealed batteries still release gasses. IDK about gel but I would assume they probley do to. If your box is sealed then I would just run a piece if 3" PVC under the car with a Computer fan pulling air out. As for the propane tank it is illegal by federal DOT reg's to carry a propane cylinder in the passenger area. Here in maine you can only transport them in a pickup bed. any other method is illegal.
Sep 17, 2011. 5:35 PMben2go says:
AGM and gel batteries do not release any gas.There is no vents of any type on those batteries.This is all I run in my vehicles because there is 100% no emissions from them.
Jan 9, 2011. 5:21 PMben2go says:
Ok.Then you are golden there.
Jan 9, 2011. 12:07 PMDr_Stupid says:
It's not the batteries that make it illegal, friend. Transporting a cylinder in an enclosed passenger cabin is against DOT regulations, as is operating a combustion engine in the passenger compartment.
Jan 9, 2011. 1:27 PMmenahunie says:
I agree and any state some one lives in that has vehicle safety inspection as where I do will not pass the inspection with this "conversion".
Also propane is a heavy gas and any leak it will accumulate at the lowest point in the car and then BOOM...
As for your (bennelson) statement of no possibility of sparks you are wrong - THE GENERATOR. Also you have the generator sucking it's air from the passenger compartment as well. I would never ever drive or be in a car like this.. Now if it was in a pickup truck; I would put these items except the propane tank into a truck tool box. Then use a DOT tank mounted either in the bed or under the truck..
This would work except you will have to enclose it in a heavy sheet steel and insulated box with vents to outside and the propane tank mounted OUTSIDE of the car.. The tank will also have to be DOT certified - this certification means the tank will not rupture on impact in an accident if it is hit...
I and others are not putting down what you did; BUT how you did it; it is not a safe conversion..
Sep 16, 2011. 6:09 PMjpayton says:
I agree with what your saying, however this conversion looks to be more proof of concept rather than a final product. On that note if he ever got pulled over in that car they would arrest him and make him tow the car home.
Oct 28, 2011. 10:20 AMrykonen says:
I agree that this is great proof of concept. Now we just need someone to take menahunie's advice and make an Instructable with DOT certified transport so we can all see how to do it legally. Nice going bennelson!
1-40 of 141next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
282
Author:bennelson(300MPG.org)
Ordinary guy with no special skills, just trying to change the world one backyard invention at a time. See more at: http://300mpg.org/ On Twitter - @300MPGBen and at Ecoprojecteer.net
