These step-by-step instructions will show you how to make your own fabric pressure sensor. It mentions two different variations, depending on if you use stretchy or non-stretchy fabric.
The materials used for the sensor are basically cheap and off-the-shelf. There are other places that sell conductive fabrics and Velostat, but LessEMF is a convenient option for both, especially for shipping within North America.
Velostat is the brand name for the plastic bags in which sensitive electronic components are packaged in. Also called anti-static, ex-static, carbon based plastic... (So you can also cut up one of these black plastic bags if you have one at hand. But caution! Not all of them work!)
To make the sensor fully fabric one can use EeonTex(TM) conductive textile (www.eeonyx.com) instead of the plastic Velostat, but at the moment EeonTex(TM) conductive textile is only available in a minimum of 100yds.
This is an improvement on the Flexible Fabric Touchpad Instructable, using "iron-on" and plastic ex-static instead of the fabric which is less stable in maintaining resistance between the two conductive layers.
To see what we use this technology for visit:
www.massage-me.at
www.plusea.at
www.kobakant.at
VIDEO
Remove these ads by
Signing UpStep 1Materials and tools
Stretchy version:
- Cotton jersey
- Stretch conductive fabric from http://www.lessemf.com
also see http://cnmat.berkeley.edu/resource/stretch_conductive_fabric
- Fusible interfacing from local fabric store
Non-Stretchy version:
- Cotton
- Shieldit conductive fabric from http://www.lessemf.com
also see http://cnmat.berkeley.edu/resource/shieldit_super
it already comes with heat glue fused to one side
Both versions:
- Velostat by 3M from http://www.lessemf.com
also see http://cnmat.berkeley.edu/resource/velostat_resistive_plastic
- Thread
- Machine poppers/snaps
TOOLS:
- Pen and paper
- Ruler
(- Compass)
- Scissors
- Iron
- Sewing needle
- Popper/snap machine (hand held or hammer and simple version)
Firstly, instead of using batteries as a power source, would it be possible to use a USB power source? For example, you plug such a device as this into the PC using a standard USB cable?
I am creating a touch sensitive project right now and I think this design is awesome, if it would take power from a USB connection then I'd be hooking up the wires to pins on a U-HID G board (http://www.u-hid.com/home/uhidg.php) and using the touch/pressure as input. Any ideas on whether this would be possible or not?
Thnaks, I'm going to have a gander at your other projects =) Hope to hear from you soon!
anyway, o want to make something similar, but cant find the materials here.im in Malaysia..would you know of the closest place i could find something suitable..any alternative?
awaiting ur reply..
thanks
Thanks so much!
I just finished making the pressure sensor successfully and i tried to connect it to a small circuit, in order to control a small coin-type vibrator. What happened when I connected the vibrator, was that even without pressing the switch, the vibrator went on (although not very strong) while when I pressed the switch it vibrated more intensely.
I would like the switch to be like on/off type (hence switch). What I realized is that the resistance provided by the sensor is very low (around 130 Ohms as I measured it) and thus permits current flowing even when in the "off" position.
Is there any solution to my problem (like a small circuit maybe with a transistor)?
fabric button >> http://www.instructables.com/id/Three-Fabric-Buttons/
http://www.fabriclandwest.com/Notion_basics/Interfacing/interfacing.htm
it is basically a thin sheet of glue that melts when heated by the iron and is intended to "fuse" (=glue) two layers of fabric together.
I'm currently working with a velostat equivalent, Linqstat, from Caplinq. Does anyone have a suggestion on how to characterize this material? Electrically, I mean.
Thanks in advance!
Knowing that you probably have more experience than anyone with bonding and working with these materials, I was hoping you could provide some guidance.
so i would tend to recommend double sided sticky tape instead.
I would like to know that can it be tested with 1.5V battery with simple LED??
if you connect it all together with the sensor and the LED is always on, then it could be that your pressure sensor is so tight that the initial pressure is already enough to decrease the resistance of the velostat to fully power the LED, but this does not mean that your sensor does not have any range. just that it is the wrong range (too low resistance) for the LED.
hope this helps.
http://www.caplinq.com/linqstat-vcf-s-series-linqstat-volume-conductive-film.html
Regarding finding conductive fabrics in Europe... I'm looking into it. But LessEMF also ships to Europe.
CAPLINQ offers an equivalent to 3M Velostat (http://www.caplinq.com/linqstat-vcf-s-series-linqstat-volume-conductive-film.html). It's essentially the same conductive plastic but without the brand name. You can buy it directly from our website and it ships from either our Ottawa, Canada or Amsterdam Netherlands warehouse depending on where you ship to.
more info on Velostat/Linqstat here:
http://www.kobakant.at/DIY/?p=381
http://www.instructables.com/id/Conductive_Thread_Pressure_Sensor/
Also, Eeonyx offers a nice range of anti-static fabrics that have higher resistance.
Hope this helps:-)
