loading
In December 2011, the Instructables Team took to the streets of San Francisco, proudly wielding before them a 12-foot cardboard Trojan horse. Man, I love my job.
Why did this happen? We had been invited to the Autodesk Christmas party just a few blocks away from our lab and we thought we should take along a present. Something unique. Something memorable. Something big enough to conceal a crack team of cardboard-sword-wielding troops.
I had been playing around with a preview version of Autodesk's new 123D Make software, a program for turning 3D models into a series of slices that can be laser cut and assembled in real life.  This technology is tremendous fun to play around with, as it has the potential to rapidly prototype anything from elaborate papercraft projects to paneled items of clothing to flat-pack emergency shelters. This seemed like a great opportunity to test it out with a real life quick fabrication challenge: a Trojan horse.
The Trojan horse, of course (of course!), could be seen as a metaphor for the way in which Autodesk acquired Instructables last year, little suspecting the creative havoc we would wreak once we'd infiltrated the corporation's perimeter. I'm certainly not suggesting that this was our intention, only that a cynic might see it as such.
Read on to find out more about how I made the horse!
Step 1: Making the 3D model
First, I needed a 3D model.
Rather than use someone else's model of a Trojan horse, I decided to design my own from scratch. I knew that I wanted the final model to be quite simple and angular, as this would make it easier to deconstruct into a sensible number of cardboard panels. Fortunately, it's much easier to model a stylized low-resolution horse than a realistic and detailed one.
My initial plan was to have enough room in each pair of legs for someone to stand, with the person in the rear bent forward and the person in the front standing upright, much like with a traditional pantomime horse, only much larger. In fact the horse ended up so large that the person at the back would be able to stand upright quite comfortably.
I modeled the horse in Blender, starting with a simple cube and extruding new faces from it until I had a very rough outline of a horse, as shown in the first image here. I then gradually refined the shape of the horse, subdividing the edges where necessary, until I had something much more distinctive. I modeled the ears, the tail and the mane separately, then joined them to the horse with a Boolean operation.
The whole time I was modeling the horse, I was thinking, "Would this look good 50 feet tall and made of wood?" As design briefs go, I quite enjoyed that one.
Step 2: Deconstructing it in 123D Make
I then imported the model into a preview version of 123D Make. At the time of writing, the publicly available version of 123D Make does not include the "Panel" function that I used for the horse, but it is due to become available at some point in the future.
In theory, this horse model could be made using only 28 folded panels .Many of those panels, however, would have been much larger than the bed of our laser cutter. Once I'd adjusted the size limits within 123D Make, the model had been deconstructed into 119 pieces. That's quite a lot of cardboard.
123D Make lets you choose from a variety of joinery methods for your seams, allowing you to make structures from a wide variety of materials, from sewn fabric to riveted sheet metal. For one glorious day-dreamy half-hour, I contemplated making this Trojan horse from sheets of 1/4" plywood strapped together with industrial metal cable ties. Fortunately, Eric talked me down off that particular ledge of impracticality, so I went for cardboard joined together with plastic zip ties.
Step 3: Labeling and perforating the pieces
I opted for the rivet joinery method, as this automatically provides overlapping tabs and holes in the appropriate places on each panel. I spent a while fine-tuning the exact hole diameter and tab width, using scraps of cardboard to roughly test how much stress different arrangements could withstand.
123D does a great job of labeling all of the 2D pieces it generates, with each panel being automatically labeled with its own number and the numbers of the pieces that each edge should be touching. What's more, you can choose to have the precise angle of each fold labeled, letting you know whether the fold is a mountain or a valley and just how far it should be bent.
Step 4: Laser-cutting the pieces
Once I had all of my horse flesh exported as EPS vector files, then I began the arduous process of laser-cutting each piece using our Epilog laser. Although this is still inestimably faster than cutting by hand, cutting 119 different panels (each of which was also perforated along its folds and labeled with a low-power laser) took a couple of days.
At last, I had a huge pile of precisely cut sheets of cardboard, sorted into numerical order and ready to be turned into a giant horse. I had long since stopped noticing the smell of scorched cardboard that now followed me around like a bad spirit, or the soot that was ingrained into my fingertips. I was approaching oneness with the cardboard and I felt exhilarated to be embarking on the next step.
Step 5: Assembling the skin!
One brave morning, randofo and I set to putting all of this cardboard together. We started with the horse's head and quickly got into a good rhythm.
As we worked, more people joined in to help. At various points, randofo had to sit inside the horse's head to join the pieces together.
Step 6: Seam joinery
We adopted a policy of keeping all the long tails of the plastic zip tie connectors pointing inwards so that the horse would look clean and unblemished from the outside. At first, we trimmed off all of the zip ties' tails, but we soon learned that doing so created dozens of new sharp edges on which to lacerate ourselves. Stowaway passengers be warned!
Here you can see how it was all tied together.
Step 7: Steady progress
I can't recommend this method of joining sheets of cardboard using plastic zip ties high enough. They're fantastic! My first plan had been to glue everything together with hot glue, but that would have been far weaker, messier and more time-consuming, not to mention permanent.
Zip ties are light, cheap, easy to use and removable. What's not to love?
Step 8: More progress
By the end of the first day, we had the head and the front legs of the horse assembled. Future plans for a giant chess set were vaguely circling in my mind.
Step 9: Bringing up the rear
Here you can see all the tails of the zip ties pointing inwards. Standing inside the hollow horse was a surreal, tree-house-like feeling, with light filtering in through a thousand tiny holes and the soft tendrils of plastic zip ties brushing your arms as you moved.
We constructed the horse in three parts: head, front legs and rump. By the end of the second day we were ready to join all three parts together.
Step 10: Clambering over furniture
As we came closer to completion, it became harder and harder to connect the pieces of the horse together. Often, we had to hang precariously from ladders and reach an arm blindly into a tiny gap, trying desparately to feed a zip tie back through a pair of pencil-width holes.
We persevered, though, and soon had an entire headless horse. Notice that the body was completely capable of supporting its own weight just by dint of the cardboard's own rigidity and the complex nature of the folds. At this stage, there was no skeleton of any kind inside the horse. Well, no horse skeleton.
Step 11: Triumphant head installation
Connecting the head was a three-person effort. The finished horse stood at 12 feet tall. The ceiling of the Instructables Lab is only 10 feet high. Luckily, I had anticipated this and placed the horse underneath a large recessed skylight.
Step 12: Standing proud
So, in just under a week, we had a giant cardboard Trojan horse. 3D modeling meets quick fabrication. The possible meets the absurd. Papercraft meets siegecraft.
Success!
Step 13: Building a frame
During the first night that the horse stood in the Lab, the cardboard slightly buckled under its own weight, causing the horse's head to sag noticeably to one side. While this gave it a fiercely inquisitive, almost challenging, expression, I thought that it would be a good idea to reinforce it with some manner of internal frame.
I assembled most of a simple frame from beams of wood and sheets of plywood, either screwed or bolted together so as to allow it to be separated easily into two halves for transportation. To support the head, I made a simple mechanism consisting of two PVC pipes under tension, which allowed the head to be nodded up and down by pulling as thick cord at shoulder level within the horse.
The design of the internal structure was determined by the following factors:
  • It had to support the head and back of the horse.
  • It had to be partially disassemblable so that we could get the darned thing out of the door.
  • It had to be mountable on a rolling wooden platform for transport to Christmas parties and sieges.
  • I had plans to turn the inside of the horse into a standing desk and workspace afterwards.
  • I also had vague plans of using the horse as a kind of portable bar, where punters could stick their heads (one at a time, please) into the belly of the horse and be greeted by friendly bartenders with cocktails inside. This may yet happen.
Step 14: Making it move
I made a four-wheeled dolly from 2x4s and plywood. The sheets of plywood were reinforced from below and positioned so that each one would support one pair of the horse's legs. I threaded a heavy duty nylon cord through two holes at the front of the dolly, so that the whole horse could be easily towed.
Step 15: Setting it free
The next stage was to rebuild the whole structure outside. This was not nearly as hard as it might sound; we simple divided the horse's hide into three parts and assembled around the wooden frame out on the pavement. I had visions of lowering the whole thing from our fire escape using climbing rope, but it turned to be unnecessary. Maybe next time.
Notice the dimly glowing plastic orbs in the horse's eye sockets. These grew more and more ominous as night encroached.
Step 16: Charge!
And so began the epic journey from the Instructables Lab to the Autodesk headquarters for the company Christmas party. Pulled by our fearless leader, the Trojan horse made its kilometer journey through the rush hour pedestrian traffic of San Francisco.
Useful tip: Cars will stop for Trojan horses. Trojan horses will not necessarily stop for cars.
I had hoped that the a few of us could stow away inside the horse with cardboard weapons, but this made it prohibitively awkward to tow.
Step 17: Obstacle en route
On the horse's first outing it encountered low-hanging branches, high-rising curbs and slow-moving pedestrians. It navigated all of them with gusto and aplomb.
Step 18: The escorts
We kept one person on either side of the horse throughout the journey. Although it never threatened to tip over, we felt reassured that there would be someone ready to break its fall if it did.
Step 19: Turned away upon arrival
Alas, when we arrived at gates of Autodesk's city fortress we found ourselves barred from entry.
"Your horse is too tall," we were told.
"We'll make it bow its head to get through the door," we replied.
"It's wheels will scuff up our polished floor," we were told.
"We'll carry it once we're indoors," we replied.
"It won't fit in the freight elevator," we were told.
"We can just leave it in the lobby. We promise it's not full of armed Greek soldiers," we replied.
That seemed to swing things against our favor. The horse stood and stared balefully through the window into the warm, Christmassy corporate building while we tried in vain to plead our case.
Step 20: Trying to grease palms
I'm not going to claim that bringing a 12-foot horse to a verbal disagreement is a good negotiating tactic, but it does lend a certain frisson to the proceedings.
Step 21: You'll have to sleep in the stables...
In the end, we parked the horse on the Embarcadero, under the watchful gaze of some very uncertain police officers. We took turns keeping an eye on the horse while the others went inside for cake, alcohol and socializing.
Those of us who stayed with the horse soon discovered that the internal frame was strong enough to support two people's weights, and we promptly withdrew to eat, drink and listen to music within its spacious belly. Yes, our Trojan horse had been turned away from the party, but sitting cross-legged inside my giant cardboard horse, sipping a beer and munching on some snacks, I had one of the most pleasant winter evenings I can remember.
<p>hi - very nice</p>
<p>This is pretty awesome! I'm just getting started with 123D Panel function!</p>
<p>I know I'm about three years late to the party, but this is SO RAD!! I came here looking for tips on creating low-poly shapes (I want to create some welded sheet metal forms), but I ended up being totally riveted (get it?) by the story. Great writing, too!</p>
<p>sencillamente genial</p>
It's great! What about 3d-model file?
Relly Nice
This is really great! I work at an inpatient psych center for adolescents- this would be an awesome project for them. Do you share the patterns or a kit?
<strong>This is the greatest instructable ever.</strong>
I have seen this thing in person, a few times. Once at the HQ, and once at Maker Faire. It is pretty darn big, but i didn't know it could support people inside.
Holy cow this is so cool!! Great 'able
awsome! how many people can you fit in it? when are you making the rest of the chess peices?
I hardly ever take the time to make a comment, but your presentation is so fun, impressive and clear I just have to say: BRAVO!
Wouldn't &quot;giant&quot; trojan horse...imply larger than the original? JUST SAYING :D
I don't know. how big was the last horse you made out of paper then? XD
Yeah how many Greeks could you possibly get into this paper model? Wait a minute, this is the Internet, I don't want to know!
Beware of geeks bearing gifts. . .
No it is beware of geeks bearing gifs.
&quot;What about a large wooden badger?&quot;&quot;
Run away!
HEY! I walked by you on the street last month! It's super cool to see you here on Instructables. :)
50' and made of wood? The one I helped design and build did. See Bart's link. Google Sketchup and Vectorworks.
Employee &quot;Sorry I was late boss, there was a giant horse crossing the street, no joke&quot;<br><br>Boss &quot;Oh don't worry it was just the Instructables team again&quot;
Fantastic! I saw this model in person and I have to say that is just as amazing in real life!<br><br>One minor note: The terminology of &quot;Papercraft&quot; only applies to card stock or lighter sheet construction. For posterboard and heavier material, the correct usage is &quot;Cardboard- Engineered&quot;.
amazeballs. pure amazeballs. Great work Oliver! I love hearing people's reactions! And i love getting asked by our neighboring buildings &quot;what was that giant horse all about?&quot;
I'd like to suggest people gather up coroplast political campaign signs after an election to use for cardboard projects. A trojan horse made of these would be quite a statement. Another ACAD instuctable &amp; or cardboard project 'd like to suggest is solar cooker plans, aluminum foil is glued to the cardboard or coroplast.
This is beautiful! I wonder how you'd feel about posting the templates for each piece? I teach middle school and would love a building project like this with them.
Pretty cool, but I don't know if you can call it a giant Trojan horse. I mean, it's pretty small by Trojan horse standards, unless you plan on smuggling in a crack team of midget assassins.
I was just about to post about the size of it... then I logged in and your comment was here. Glad I'm not the only one who thought that. =P
Just thinking that. Maybe it is a Giant Miniature Trojan Horse?
..WOW...this reminds me of the Iranian government's recent campaign against Western influences of the &quot;Barbie doll.&quot; How did you come-up with this idea?<br><br>BRILLIANT!<br><br>Ref: http://www.guardian.co.uk/world/2012/jan/24/iran-barbie-doll-crackdown-campaign?newsfeed=true
It's like a teeny tiny version of the one that burned on the playa.. see bartholomew's link below..
This is just wonderful.<br><br>(And by the way, I hope you've seen the adventures of this Trojan Horse in Australia... http://www.youtube.com/watch?v=Xs3SfNANtig )<br><br>Thanks for the great - and inspiring - documentation!
wow!!!!
Stuff it with Spartans and go raid something, just AWESOME!!!
@PenfoldPlant; I tweeted it. Why oh why are we so fascinated with the Trojan <em>Equus ferus</em>? That said, how many papercraft Trojans can you fit into it? Cheers! : ) Site
&quot;Would this look good 50 feet tall and made of wood?&quot; Yes, yes it would. :)<br>http://www.flickr.com/photos/bobbiesal/6219121331/in/pool-1728824@N25
Love the video! It was a funny story. <br>I could hear Randy saying that!<br>Tell Randy his mother says hello! :-)
Splendid! What an achievement, congratulations!
Epic Beyond Belief!
I'm so excited this is fully documented now. :D
Did Randy say &quot;Next time I ride in the front and no stopping at Taco Bell?&quot;
About This Instructable
43,633views
156favorites
License:
Bio: Artist in Residence at Pier 9, currently exploring a vast array of new tools with which to injure myself.
More by PenfoldPlant:Candy Hearts (made with real heart) Haggis Pops Explosive Cocktail Foam
Add instructable to:
