Here are some pretty easy directions for you to make a hand made foot stool. This is a project I am planning on doing at my school with my third graders. It will be a mixed media experience that will include working with wood and tools ,as well as, fabric and sewing.
My third graders study Northern Africa in Social Studies and I am considering doing this as a cross curricular project and have them print their own patterns on the fabric they use for their stool.
Step 1: Supplies
11.5" X 11.5" wood, (pine or knotty pine)
$ pieces of 6" (pine or poplar) 1.3/4X1.3/4 for the legs
foam 2" cut to 12" X 12"
Fabric 22" X 22"
8 long screws (I use 2.5" wood screws)
Cabots stain (or polystain, 1 step interior wood stain)
brush
rags
scissor
needle
thread
sandpaper
ruler
stapler
staples
drill
screwdriver
upholstery tacks (28)
  optional.......spray adhesive, wood glue
Step 2: Sanding
Sand all edges of wooden pieces
Step 3: Staining
Stain legs and table top. If you have access to an outdoor area it may be best to work outside. You can use any shade of Cabot stain or Cabot Polystain.
Apply stain with a brush and wipe away excess with a rag.
Step 4: Placing legs
Measure 1" and mark on un-stained side of top
Step 5: Stained side of top
Flip the wood and mark off an inch border on the stained side of the wood
Step 6: Wood glue
place the legs in the four marked off corners of the stained side of the wood and secure with wood glue.
Using wood glue helps hold the legs in place to prepare for the next step.
Step 7: Drilling
When the wood glue is dry, drill a starter hold through the top (un-stained side of wood) down into the legs.
Step 8: Screwing
Screw long screws through top and into legs. I use two screws in each leg to prevent it from spinning and getting loose.
Step 9: Fabric
turn and sew a 3/4 inch hem around all sides of fabric. I will have my kids hand stitch this as part of their project, however, if you have a sewing machine it can be machine stitched.
Step 10: Stapling fabric
At this point I like to lightly cover one side of the foam, and, the top of the wooden surface of the stool with spray adhesive. This will help keep the foam piece from shifting.
Turn the stool over onto the middle of the fabric and begin to staple the edges to the under side of the stool.
staple two sides across from each other.
Step 11: Corners
The corners can be tricky. With the un-stapled side facing you pull up one edge and staple it in front of the leg.
Step 12:
next pull the outer edge of the fabric up and over the stapled section.
Step 13: Corner
now fold up that final edge and staple the corner. Repeat this on the other corners and finish securing with staples around the edge.
Step 14:
Step 15: Tacks
Beginning on one side of your stool hammer in an upholstery tack.
Step 16: More tacks
Now hammer another tack on each side , approx 1.5"-2" away.
Step 17: Add more tacks
Continue to add tacks. (I think 7 on each side spaced out looks nice. ) Work your way around the base of the stool.
Step 18:
Step 19:
Step 20: Finish
You are finished with your foot stool, sit back, relax, and put your feet up!
sooooc says: Nov 15, 2012. 1:33 AM
a little bit short, but awesome! tks
Julianne fights Dragons! says: Nov 10, 2012. 11:35 PM
Ooohhh this would be an awesome project to do next week!!!! Great job with the intructable!
Susan Cirigliano (author) says: Nov 11, 2012. 6:40 AM
Thank You
Lisa Arbolino says: Sep 27, 2012. 5:10 PM
Nice project. Easy to follow instructions. Great end result!
Barbara Stromberg says: Sep 26, 2012. 7:42 AM
This is really nice....some of John's woodworking skills and looks great!! must be rubbing off on you!!
The kids will love making this...so useful
lavothas says: Sep 21, 2012. 6:40 PM
I agree with Schmidty, a bit of padding on the top of it would make a more comfortable seat, and not add much more to the project for complexity.
Susan Cirigliano (author) says: Sep 21, 2012. 8:44 PM
Schmidty
Susan Cirigliano (author) says: Sep 21, 2012. 8:43 PM
I agree with Schmidty as well, please read my response to Schmidth's comment!
thanks.
Schmidty16 says: Sep 21, 2012. 5:29 PM
did you put cushion in it it would feel better
Susan Cirigliano (author) says: Sep 21, 2012. 8:41 PM
OH MAN....I did put cushioning in it, in my supply list I mentioned 2 inch thick, 12"X12"foam pad, and in step 10 I talked about using spray adheasive to secure the foam to the top of the stool before I flip it onto the fabric to begin to attatch it, however, I forgot to insert a photo!
sorry
Maritza Schaeffer says: Sep 21, 2012. 7:36 AM
This is very cool! What a great idea for a project to do withyour students - I love it
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
