Remove these ads by
Signing UpStep 1Things you will need: -
One AC Transformer of 220 to 12 volt AC, 1Amp.
240 Bright White LED’s size 5mm.
Mild steel wire to make the supporting rings.
Electrical thin wire, solder etc.
5mm Iron Rod to make the HOOK.
http://images.travelpod.com/users/pbprogo12/1.1275378962.large-metal-expanding-ball.jpg
so how r u ? and wats is next in line ?
I have not yet thought about my next Project.
The inspiration should come on its own.
In india, u should really start selling this kind of stuff...
I dont think iv seen something so creative around!
btw, you could improve efficiency by wiring all the leds in series using 240v DC.
AC supply-Bridge rectifier-220v DC
Only problem is that in places like india, there are frequent fluctuations and that could result in problems (i have seen 195-246v) in my area
As you know all the sides are visible in the hollow sphere, whereas you can only see one side of an opaque ball.
You will agree with me that a hollow sphere has a beauty of its own?
though for other ideas.
Not all the LEDs will have the same forward voltage either.
You will probably soon find that one will fail, then another and then eventually all of them without any current limiting (usually a resistor in series).
Three years is a long time for a trouble free performance, so why should I change my formula of 12 x 1.4?
SEE STEP 3 for details.
Once again you pull off the wonderful!
Just the thing for a light for my buddy's cabin, (Most of his lighting is from a solar/battery system, and this will be a hit!!!!!!!
You do have a knack for this!
You got it right.
You are entitled to your ideas but, there is always a risk involved with using 220 volt AC. directly.
let's the party start !
reg
ketan
"May the good belong to all the people in the world.
May the rulers go by the path of justice.
May the best of men and their source always prove to be a blessing.
May all the world rejoice in happiness.
May rain come in time and plentifulness be on Earth.
May this world be free from suffering and the noble ones be free from fears"
---- Vedic blessing
You will get *thousands* of hits there "per day" and therefore, more ppl in the world will be able to find something useful.
Also, you can provide a link of your i'bles in your videos, so those who, after seeing the videos, want to read in detail, can visit here....
my 2 cents...
reg
ketan
Your solution and instructions are so simple that even I can follow them. Not only do you have the ability to make the electronics simple, you have a knack for explanation too.. Thanks for sharing.
Only problem with color LED's are that they do not give enough light to light up your rooms, and my intention is to have no other lights in the room except the Globe.
In India it will be about 5$.
