Remove these ads by
Signing UpStep 1: Gather your materials
Besides the LED you will also need a driver circuit. Since the plan is to build an LED replacement for a low voltage lighting bulb, we need a driver that can handle an AC input. Low voltage lighting uses a transformer to reduce the typical 120VAC power to a "low" 12VAC level. www.ledsupply.com conveniently sells an AC capable "buckpuck" that will accept 12VAC input and output a regulated 0-700mA output current for driving strings of LEDs.
So go ahead and shop at LEDsupply or equivalent to get the electronics parts. If you want to be able to dim your LED bulb you will also need a potentiometer. The Endor Star will need to be mounted on a heat sink, such as a section of aluminum angle or channel extrusion. This will require holes to be drilled and tapped as well as screws, heat sink compound, and some wire.
Materials:
1. Power led such as a 3-up Endor Star with 3 Luxeon Rebel 90 lumen LEDs
2. Constant current LED driver with AC input ability such as BuckPuck 03021-A-E-700
3. 1.25" section of aluminum extrusion for heatsink
4. 4-6 screws fro mounting LED to extrusion, 6-32 works great
5. Tap for threading holes for screws, 6-32 tap works great
6. Heat sink compound for mounting LED to heat sink. Since the LED is isolated, you can use a metallic based heat sink paste like molybdenum anti-sieze
7. Some wire to hook everything up
8. Soldering tools and a clue
Visit Our Store »
Go Pro Today »
As old as this instructable is, the Feit bulbs that I have seen are still poor performers in comparison. The efficiencies are miserable, at around 40 lumens per watt. This is in line with a bad CFL. The majority of commercial bulbs are not up to snuff yet, especially the cheap no-name ones coming out of China. There are some good bulbs being made by TESS (and sold through FIRST robotics teams) that are approaching 80 lumens per watt using Cree LEDs in a nice package at $20 subsidized by Google, and Philips has a good bulb with similar specs for $40 (http://www.amazon.com/Philips-Ambient-Dimmable-Replacement-Light/dp/B004IUMGV4).
Thanks for reading.
http://www.instructables.com/id/Replace-Low-Voltage-Bi-Pin-Halogens-with-LEDs/
Since then, I have made similar bulbs with the Cree XP-G stars which are significantly brighter at the same power. The pictured bi-pin has a couple thousand hours under its belt of trouble free operation. It is the most used light in the house.
Unfortunately, I only managed to find one distributor (Farnell) so far: Order code is 1734729 from www.farnell.com
No driver required, literally plug and play. (Oh, must use heatsink of course :) ), so to make LED light bulb is now even easier!!
PS: Just type '230V LED' on the search box of Farnell's website if you can't find it
I haven't tried how it works in practice. Will probably flicker like my other 'cheap' 230V LED. Looks like cheap LED lighting is just simply not there... yet :)
http://www.snopes.com/medical/toxins/cfl.asp
Here is the station I use:
http://store.sra-solder.com/product.php/6266/26
BTW, do you know why is that low voltage lamps works with its 12VDC transformers, but not with for example a CAR battery with also 12VDC? Cheers!!!
