3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Quick and dirty LED flashlight.
This is my Instructable for the LED contest.  This is also my second Instructable to so go easy on me.
In this Instructable I will show you how to make a quick and dirty LED flashlight.
Step 1Materials
Materials
3v coin cell battery (I used a CR2032)
Momentary push button switch
LED (obviously)
Electrical tape (optional, not pictured)
Small length of wire
9 comments
May 12, 2011. 9:15 PMdoflagie says:
Try conductive glue...
http://www.instructables.com/id/Make-Conductive-Glue-and-Glue-a-Circuit/
Sep 2, 2010. 6:49 PMmdchumley says:
you could use a battery holder. Sometimes circuit boards have these and you can solder to the holder contacts.
Aug 31, 2010. 8:25 PMmdchumley says:
Do not ever solder on a battery. These are very dangerous and will explode. I have seen an experienced electronics technician do this and got by with two or three, but the last one exploded and luckily he had on his safety glasses.
Sep 1, 2010. 10:13 PMHM-Innovations says:
The danger in during soldering, you are over heating the battery and placing it under high temperatures that can cause it to leak, explode, or just simply destroy the battery. If it explodes and the acid enters your eyes, you could permanently damage your vision.
Sep 2, 2010. 6:31 AMHM-Innovations says:
You can salvage the battery container for the button cell battery from another object. You can use a clothes pin to hold the cables to your battery. You can also use tape (less permanent)... lastly for this kind of project you can leave the leads unattached and then use the force of your thumb and index finger to press down on the leads to light the LED. Make the end of your cables into coils or a small ball, that way you have more surface contact if you're going to tape them to the battery. .. anything but solder :P
Sep 2, 2010. 3:53 AMmdchumley says:
Buy batteries with solder tabs. These are more expensive and may be harder to find, but they are made for the purpose of soldering.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:pgd5000
I'm just a 16 year old kid who like to build stuff. I don't like most kids my age because most of them are extremely immature. But my circle of friends is pretty mature.
