3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Reprap Mendel K'nex Frame
Reprap Mendel K\
  • last photo ←
Reprap is an open source project to create a 3D printer that can make its own parts, essentially printing itself. While looking through the RepRapWiki one day, I found the FTIStrap which is a Repstrap made out of fischer technik parts. I didn't have any access to fischer technik parts, so I decided to recreate the Mendel frame out of k'nex.
The overall goal of this project was to create as much of the mendel frame and chassis as possible, so you would only have to add motors, belts, and electronics. Additionally, while k'nex would not be suitable for long-term use, they should be good enough for enough prints to create a set of parts for a reprap machine. I tried to make as much of the project out of k'nex as I could--the only exceptions are the nuts, aluminum tape, threaded rods, and hot-glued lego gears (I had to grind out the central hole to have them fit on the threaded rods) on the z-axis.
An issue that I had with the final design was that since the top joint of the frame was not at a 45 or 90 degree angle, it didn't fit perfect, causing the z-axis rails to flex a bit. Another thing to note is that since the build platform is a plastic, blue k'nex plate, it would have to be covered with a heat resistant material before actually printing.
(I apologize for the lack of notes on the photos. I tried firefox 4, chrome 10, and safari, and none of them were able to properly create and save notes on the images.)
4 comments
Jul 17, 2011. 8:48 AMdombeef says:
Any new news?
May 18, 2011. 8:19 PMfostersfriend says:
You could even add gears and chains for the x axis kenex sells them with roller coaster sets
Apr 21, 2011. 2:20 PMlmaya says:
very cool but are you going to actually turn it in to a working mendel
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:Superchef
