So I came up with the idea of making an Automated LED Wardrobe Light that would save me the inconvenience of looking out for my clothes with only one hand as the other was holding the torch. A gadget that was easy to assemble, reasonably cheap and very practical in our day to day lives.
This Automated LED Light can be used in your wardrobes, under-bed storage area and in modular kitchen cabinets. The Automated LED Light that I have made, uses a 9v battery as the source of power. However, power from a wall wart or a cell phone charger can also be used to power the Automated LED Light.
The Automated LED Wardrobe Light circuit is made in such a way, that when the wardrobe door is opened, the LED Lights automatically turn on and when the door is closed, the light automatically switches off.
Remove these ads by
Signing UpStep 1Parts Needed :
Supplies :-
1. 1pcs High Power LED 1watt.
2. Aluminium Heatsink.
3. SPDT Switch.
4. LM317.
5. 3.9 ohm Resistor.
6. Circuit Board.
7. Heatsink Compound.
8. Heatshrink Sleeve.
9. Glue.
10. Wire.
Tools :-
1. Hacksaw.
2. Drill.
3. Soldering Iron.
4. Solder.
5. Soldering Wax.
Therefore:
Given a 9 Volt battery,
a LED FV of 3.5, and
a LED DC Forward Curent of 0.35 Amps
See
R = V/I = (9V-3.5V)/0.350A = 5.5V/0.350A = 15.7 Ohms
And Joules Law:
Power (Watts) = Volts * Amps
P = V * I = 3.5 Volts * 0.350 A = 1.225 W
which the data sheet allows as it says the 1 W LED actually can source 1.4 Watts.
So I do not think you need the LM317 either.
JVG>"to regulate the amount of current"
The very definition of a resistor.
It really doesn't matter. Build your circuit with whatever components make you comfortable...I just was suggesting an alternative but you are welcome to ignore me.
Nice job overall, I hope you post more.
Regards,
Rod
For builders in the U.S. LED supply has all the parts you need including a buc puc which regulates the voltage automatically.
There are many stores in Lamington Road the more quantity less is the price
1wat high luminescence led the one shown above costs rs.25 each (i still think am fooled here)
the alien pad i.e. heat sink on which Led's are attached are rs.5 each
the other leds not high intensity one
cost around rs.2 each if purchased in lot ten 1.50
if more amount like 500 or 1000 ten 1rs max
the heat sinks which is used in other prjs for LEDs are rs.5 each
TIP 41 transistor - rs 15 each
3.5 mm jack rs - 15 each
enjoy
nw peoples asking abt shops in other states sry no IDEA :)
anyways last thing i wud like to ask i will be designing aquarium light from this and i want that led's will b turned ON continuously what to do in such cases
how to save them from frying and what resistors to use
what i will be doing is connecting 5 LEDs in parallel so 2rows
i.e. 10 LEDs per row and using mobile charger as source then what can b done in such case resistor values what i cant count
Charger Details : nokia : o/p -> dc5.0v -- 500mA
Can u please help me with it
Where did you get those 1 Watt LEDs ?
Price.
Mumbai
Where did you get the high powdered LED.
