3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Radial Arm Saw -- A Guide of Sorts
The radial arm saw is a very versatile machine around which a whole shop can be built.  It is one machine that allows a number of operations normally requiring different specific machines.  Unfortunately, electric miter saws have displaced the radial arm saw.  That is probably because many used a radial as only a glorified miter saw or cut-off saw.  This Instructable will pull together in one place a number of Instructables demonstrating various capabilities of a radial arm saw, as well as some dealing with wear and maintenance issues.  Just click on the hot links in the frames below.
Step 1Aligning the saw
Aligning the saw
The radial arm saw has several adjustments that need to be aligned properly for accurate cuts.  These do have indexed settings.  The owner/operator must set these properly.  They include setting the tilt of the motor so the blade is 90 degrees to the table.  The arm can swing and must be set so it is 90 degrees to the table's fence.  The most cumbersome adjustment in my experience is getting the arm 90 degrees to the fence.  But, with a slight revision of the process outlined in the owner's manual and an addition to the table, it is not difficult at all.  In use vibration can change the settings of any saw a little.  The the saw needs to be checked occasionally to make certain the arm is still square to the fence.
64 comments
1-40 of 64next »
Nov 6, 2011. 4:55 PMshinju says:
hello. well i would also like to help out on the blade choice for the ras. the best i found that works good is the woodwoker two blade by forrest blades. i use the 60 tooth triple-chip blade.also you can make 8 cuts with the ras.crosscut,miter,rip,blade tilted- bevel crosscut,compound mitre,bevel rip with the blade horizontal-two edge cuts horizontal for slot.tilted for raised bevel.hope this helps out.feel free to aks any more questions will more than happy to help.
Nov 6, 2011. 4:42 PMshinju says:
hello i have an dewalt ras #1030.dewalt made the best ras made hands down.if you want trya ras,try to get an dewalt model. hear a a few hints.1. find a saw with at least 3/4 or more horse power.2. find one with the adustment handle in the back. 3. and most important start the motor and make sure it runs,if not dont buy it, trust me it can be very costly to repair ar replace a motor.also the best book out there on ras is " how to master the radial arm saw" by mr.sawdust.it is the best book for using and setting up the dewalt ras. hope this helps anyone how would like to try the saw.remember the saw does not have a brain. if something happens it is your fault not the saw.
Nov 14, 2010. 5:45 PMjb33 says:
Thanks for all the good info.
I have a 1950's vintage DeWalt radial arm saw that came from my grandfather. I've had it for 40 years and used it for all kinds of projects. It still works great. A few months ago, I had to replace the original key switch. That's the only repair I've had to do.
Aug 6, 2011. 9:26 AMbluesblood says:
I have an old DeWalt radial arm saw and a DeWalt scroll saw of round about the same vintage. Both are built like a tank and in great condition just waiting for me to restore them and put them in my shop. The radial saw, hasnt been touched yet but needs a little tlc. The scroll saw I've already rebuilt, but need pulleys and belt to connect a motor. I havent had the time to put into either just yet, but I'm pretty excited to get them running and put them to good use.
Dec 16, 2010. 11:29 PMpfred2 says:
DeWalt invented the draw saw as they called it. What we now know as the Radial Arm Saw. So what you have is not only vintage but the original!
Jan 4, 2011. 9:21 PMfretted says:
I bought the exact same saw from a freind about a month ago exactly the same one except mine was in very very rough shape i had to rebuild the lailshaft and bearing housing the frontshaft housing was dismantled the angle lever was locked up and would not move ....
It took me 3 days of a weekend to dismantle and repair it but now it runs and works great i still have to make a descent table for it but for 25 bucks im satisfied
It makes me happy to see you have one in such very good condition
Thumbs up for this guide to
Thanks
Nov 16, 2010. 3:22 PMfizzox says:
Hi Phil, I wanted to thank you for providing some great information. I just got into woodworking having worked mainly with steel and electronics in the past. To help me out, my family members were nice enough to give me their extra woodworking tools including a thirty year old craftsman radial arm saw. I am very comfortable working with table saws, mitre saws etc, but have no experience with this beast of a tool. Having found this post, I can't wait to make the most of my radial arm saw now that I've discovered such a great guide. To those who find any sort of woodworking tool less safe than getting in their car everyday are simply ill informed. I am confident that with your guide and a unique ability called common sense I will not lose any fingers. The only problem I currently have is that the original sheet metal table for the saw was damaged while being moved across the country and I had to scrap it. Could you give any tips on building a new one?
Dec 16, 2010. 11:24 PMpfred2 says:
The biggest unknown safety trick with RAS is blade selection. You want a blade without positive rake to it, and a small gullet too. It keeps the tool from self feeding so much. Read they make special blades for these things, and you should try to make sure you use one, or one as close as you can get to one. I don't know how they get away with such aggressive blades on the new chop saws, but those aren't good on RAS. Do some research and make sure you are running the correct type of a blade.
Nov 18, 2010. 3:30 AMfizzox says:
I do have the original manual, unfortunately the original table is gone. I'll have to find one I can buy somewhere or build a new one from scratch before I have to worry about alignment.
Nov 16, 2010. 11:10 AMdpapas665 says:
So, much has been made of the danger of this tool. But is it statisitcally any more dangerous than a table saw?
Dec 16, 2010. 10:54 PMpfred2 says:
Well a Radial Arm Saw does have a tendency to self feed. And the blade moving as opposed to being fixed can present more of a hazard than a fixed blade does too. I run my RAS with no blade guard on it at all. I don't count on junk like that to protect me, and it gets in my way of seeing what I am doing. I can still count to 10 without taking off my socks ...
Nov 16, 2010. 3:28 PMMoore. Matt Moore. says:
The day I'm not terrified of my shop machinery is the day I need to give them all away.
I've been using my table saw and radial arm saw for nearly 20 years, and they scare the hell out of me. Even my drill press has the potential to hurt me badly. This forces me to do one of two things: use them very very carefully or not use them at all.
Great write-up, Phil. I rarely use the radial arm saw outside of crosscutting because getting it square again is such a pain. Will try your stuff soon. Thanks.
Dec 16, 2010. 10:49 PMpfred2 says:
Your best bet with an RAS is to square it up and leave it square and use axillary tables for any other kind of a cut. I think they put all them adjustments on RAS just to screw people up! Since I've gotten mine perfectly square I just leave it that way. And yes it was a pain!
Nov 7, 2011. 10:42 PMbike_geek says:
Hi Phil;
You are obviously a good craftsman and I respect the time you have taken to pass on your knowledge.
However gloves should never be worn when using any power tool, that scuffed skin could have become a broken wrist or an amputated finger if you had been wearing gloves. Where skin will cut a tougher glove may catch and draw in.
One of the first lesson you learn at a trade school is when using power tools, no gloves, no jewelery, no rings.
Cheers
Joel
Nov 16, 2010. 12:18 PMjeff-o says:
See, now I wish I had room for one of these. Do you think it would be OK to keep it in the (unheated) garage, or is that asking for trouble?
Dec 7, 2010. 3:16 PMneffk says:
Cold is fine.
http://www.instructables.com/id/Radial-Arm-Saw-Overhaul-Modification-for-Low-Pro/
Dec 16, 2010. 10:28 PMpfred2 says:
Motor oil contains a detergent that attracts water, which is fine in your motor because cylinders firing flash it off, but isn't so great for metals that aren't in combustion chambers ... Get a quart of chainsaw bar oil it is a far better general shop lube. One car product that isn't too bad for metal protection in a workshop is paste wax. Though some say the silicone in some waxes can adversely affect wood finishing. I've personally never had a problem with it. Leave motor oils in motors which they were engineered to be in. Another trick for humid shops is to run a fan in them. It stops water from condensing on cold metals. My RAS doesn't vibrate when I run it, if it did I'd change the blade to a better balanced one and check the bearings and brushes. Possibly repack the gears as well.
Nov 16, 2010. 5:20 PMjeff-o says:
Good to know. I want to get a radial arm saw and a table saw, but the garage is the only place where I'd have room to store or use them. I was worried they wouldn't survive -20 celcius winters and humid summers, which is why I haven't bought either one yet. Radial arm saws are dirt cheap on Kijiji, too - plenty for under $100, and really good ones with all the accessories for $200-$300.
Nov 16, 2010. 11:05 PMjeff-o says:
Well, it's not like I'd be using it when the temps drop that low -- no, when it drops to -20 I bury myself in a blanket and watch a movie, hot chocolate in hand.
But, the saw should survive the winter and be ready to go when my fingers thaw!
Nov 17, 2010. 6:46 AMjeff-o says:
I've been thinking of installing a heater in my garage. But before I do that, I'll need to update the wiring in there. Currently the power consists of an overhead wire that stretches between the house and the garage, that looks like it dates back to the late 60s... Fine for some lights and a garage door opener, not so great for power tools pulling 15 amps! I actually want to install both 120V and 240V, in case I ever get my mitts on a welder.
Nov 17, 2010. 8:33 AMjeff-o says:
Yeah, a 120V welder would probably be enough for me, as I wouldn't be doing any heavy welding. But, 240V would be nice to have, and if I'm running a line from the main fuse panel to the garage then it may as well be a big, fat line!
Dec 16, 2010. 10:37 PMpfred2 says:
Big fat lines cost big fat dollars. When I ran a #6 220V line to my garage it cost a couple hundred. But the right way to go would be to install a subpanel with a fairly decent feed cable to it.
Dec 17, 2010. 4:39 AMjeff-o says:
Yeah, I figured that's how much it would cost. I figure I'd need a subpanel just to split up the 220 to 110 as well, since most of the tools being used in the garage would need that.
Dec 18, 2010. 9:04 AMpfred2 says:
Yes copper is pretty expensive, just the cable wire was a couple of hundred. You seem to have the right idea to me. I've a different attached garage workshop now. I made a video of sorts about it recently:
http://www.youtube.com/watch?v=dkgFQa5lzzM
My Radial Arm Saw pops up in it with fair regularity. It was the first machine tool I moved.
The video goes along with an Instructable I made with my lost account here:
http://www.instructables.com/id/Design-a-workshop/
Nov 14, 2010. 8:21 AMwingnuts says:
Please be aware -Sears has recalled 3.7 million radial arm saws ... Free repair or $100 if it is too old to fix -
http://www.cpsc.gov/CPSCPUB/PREREL/prhtml01/01031.html
1-40 of 64next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
476
Author:Phil B
I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my...
more »
