Introduction: #16 Fusion Wednesday - Flexible Shaft Coupling | Fusion 360 | Pitacchio Graphic
About: Channel dedicated to learning Autodesk Fusion 360, Blender e Affinity Designer.
Look how easy is to make a Flexible Shaft Coupling for CNC on Fusion 360.
Follow the tutorial video:
https://youtu.be/vGPQoBuB7io
Follow my youtube channel tutorial:
www.youtube.com/@pistacchiographic
Software that was used in this project:
OBS Studio: Record the screen
Fusion 360: CAD design and PDF drawing instructions
Affinity Designer: Make the thumbnail
Affinity Publisher: Make the Technical Drawing E-Book
Step 1: 2D Sketch
Start followwing the 2D sketch.
Step 2: Extrude
Make a cilinder with 19mm of diameter and a 25mm depth, after make a hole with 8mm of diameter and a 14mm depth. Another hole with 5mm and a 11mm depth.
Step 3: Side Hole
Space between the two M3/0,5mm hole are 16mm and 4,5mm of the bottom.
Step 4: Flexible Shaft
Make a coil profile using the 2D sketch.
