Introduction: 2.4" TFT LCD Touch Shield Arduino
2.4" TFT LCD Touch Shield Arduino UNO Hello World
2.4" diagonal LCD TFT display 4-wire resistive touchscreen LED backlight
Step 1: Scetch
#include // Core graphics library
#include // Hardware-specific library #include
#define YP A1 // must be an analog pin, use "An" notation! #define XM A2 // must be an analog pin, use "An" notation! #define YM 7 // can be a digital pin #define XP 6 // can be a digital pin
#define TS_MINX 150 #define TS_MINY 120 #define TS_MAXX 920 #define TS_MAXY 940
// For better pressure precision, we need to know the resistance // between X+ and X- Use any multimeter to read it // For the one we're using, its 300 ohms across the X plate TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
// Assign human-readable names to some common 16-bit color values: #define BLACK 0x0000 #define BLUE 0x001F #define RED 0xF800 #define GREEN 0x07E0 #define CYAN 0x07FF #define MAGENTA 0xF81F #define YELLOW 0xFFE0 #define WHITE 0xFFFF
SWTFT tft;
#define BOXSIZE 40 #define PENRADIUS 3 int oldcolor, currentcolor;
void setup(void) { Serial.begin(9600); Serial.println(F("Paint!")); tft.reset(); uint16_t identifier = tft.readID();
Serial.print(F("LCD driver chip: ")); Serial.println(identifier, HEX);
tft.begin(identifier);
tft.fillScreen(BLACK);
tft.fillRect(0, 0, BOXSIZE, BOXSIZE, RED); tft.fillRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, YELLOW); tft.fillRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, GREEN); tft.fillRect(BOXSIZE*3, 0, BOXSIZE, BOXSIZE, CYAN); tft.fillRect(BOXSIZE*4, 0, BOXSIZE, BOXSIZE, BLUE); tft.fillRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, MAGENTA); // tft.fillRect(BOXSIZE*6, 0, BOXSIZE, BOXSIZE, WHITE); tft.drawRect(0, 0, BOXSIZE, BOXSIZE, WHITE); currentcolor = RED; pinMode(13, OUTPUT); }
#define MINPRESSURE 10 #define MAXPRESSURE 1000
void loop() { digitalWrite(13, HIGH); // Recently Point was renamed TSPoint in the TouchScreen library // If you are using an older version of the library, use the // commented definition instead. Point p = ts.getPoint(); // TSPoint p = ts.getPoint(); digitalWrite(13, LOW);
// if sharing pins, you'll need to fix the directions of the touchscreen pins //pinMode(XP, OUTPUT); pinMode(XM, OUTPUT); pinMode(YP, OUTPUT); //pinMode(YM, OUTPUT);
// we have some minimum pressure we consider 'valid' // pressure of 0 means no pressing!
if (p.z > MINPRESSURE && p.z < MAXPRESSURE) { /* Serial.print("X = "); Serial.print(p.x); Serial.print("\tY = "); Serial.print(p.y); Serial.print("\tPressure = "); Serial.println(p.z); */ if (p.y < (TS_MINY-5)) { Serial.println("erase"); // press the bottom of the screen to erase tft.fillRect(0, BOXSIZE, tft.width(), tft.height()-BOXSIZE, BLACK); } // scale from 0->1023 to tft.width p.x = tft.width()-(map(p.x, TS_MINX, TS_MAXX, tft.width(), 0)); p.y = tft.height()-(map(p.y, TS_MINY, TS_MAXY, tft.height(), 0)); /* Serial.print("("); Serial.print(p.x); Serial.print(", "); Serial.print(p.y); Serial.println(")"); */ if (p.y < BOXSIZE) { oldcolor = currentcolor;
if (p.x < BOXSIZE) { currentcolor = RED; tft.drawRect(0, 0, BOXSIZE, BOXSIZE, WHITE); } else if (p.x < BOXSIZE*2) { currentcolor = YELLOW; tft.drawRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, WHITE); } else if (p.x < BOXSIZE*3) { currentcolor = GREEN; tft.drawRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, WHITE); } else if (p.x < BOXSIZE*4) { currentcolor = CYAN; tft.drawRect(BOXSIZE*3, 0, BOXSIZE, BOXSIZE, WHITE); } else if (p.x < BOXSIZE*5) { currentcolor = BLUE; tft.drawRect(BOXSIZE*4, 0, BOXSIZE, BOXSIZE, WHITE); } else if (p.x < BOXSIZE*6) { currentcolor = MAGENTA; tft.drawRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, WHITE); }
if (oldcolor != currentcolor) { if (oldcolor == RED) tft.fillRect(0, 0, BOXSIZE, BOXSIZE, RED); if (oldcolor == YELLOW) tft.fillRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, YELLOW); if (oldcolor == GREEN) tft.fillRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, GREEN); if (oldcolor == CYAN) tft.fillRect(BOXSIZE*3, 0, BOXSIZE, BOXSIZE, CYAN); if (oldcolor == BLUE) tft.fillRect(BOXSIZE*4, 0, BOXSIZE, BOXSIZE, BLUE); if (oldcolor == MAGENTA) tft.fillRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, MAGENTA); } } if (((p.y-PENRADIUS) > BOXSIZE) && ((p.y+PENRADIUS) < tft.height())) { tft.fillCircle(p.x, p.y, PENRADIUS, currentcolor); } } }
16 Comments
6 years ago
hi. i managed to make it working, but the touchscreen seems to be inverted. when i swipe along the x the line appears on y and viceversa! any work around that?
Reply 3 years ago
in the MCUFRIEND_kbv.cpp file in the MCUFRIEND_kbv library, remove the line INVERT_GS which comes after _lcd_replace. Then save the cpp file and reupload the code to your arduino. The display should now, not be mirrored.
3 years ago
I cant download
Reply 3 years ago
I am very sad
3 years ago
Can I mount this screen shield on another shield, specifically the shield that contains 4 relays? Everything, of course, in an Arduino UNO.
5 years ago
I have a touch display 480x320 and this code not work. Please help me.
6 years ago
Hello, how can i use hc06 or hc05 bluetooth module with this shield?
Reply 5 years ago
It seems the shield doesn't reserve any pins to use, so you cannot.
6 years ago
Plese give work code this code not work
Reply 6 years ago
I agree with you
Reply 6 years ago
im 2 not work
Reply 6 years ago
the code works you have to import the librarys
6 years ago
This code not work plese give work code
6 years ago on Introduction
Very cool, I just ordered one of these from BangGood.
But it is not an instructable for you to just show someone else's work. How about if you give some explanation on how to use Adafruit's programs to make your own display - maybe how to write your name, or something else.
Reply 6 years ago
And banggood sends at least 3 different models, completely different libs used... Instructables is being flooded with bullshit or copied stuff...
This is the touch screen demo sketch from
http://misc.ws
