Introduction: 2x4 End Table
Today I will show you how to build a modern end table with a leftover 2x4 and some scrap wood. I got the idea from a picture I saw one time and decided i would make it for the 2x4 contest.
Tools:
Miter saw
Sander
Band saw
Materials:
10' 2x4
Walnut scraps
Screws
Plugs
Step 1: Cut the Peices
You'll need to cut out seven pieces. 6 are 14 inches long and 1 is 24 inches long.The one that is 24'' long will serve as the leg. I assume that you can look at the pictures and figure out how to cut the 45 degree angles.
Step 2: Sand
This step is simple. All you do is sand... and sand... and sand. 2x4s are not the nicest wood so it can be difficult to make nice things out of them. A planer would make this much easier, but I don't have one.
Step 3: Assemble (Without Glue)
Drill 1/8 inch holes into each corner from the side. Countersink them with a 3/8" bit so you can add plugs later. Make the top and bottom pieces separately and attach the leg to the bottom. The screws I used are deck screws because they are good and sturdy.
Step 4: Glue
Take the screws out and glue the top and bottom together (separately) with the leg on the bottom piece. Once the glue is dry, you can attach the top to the bottom. Clamp the top in place and use shims to make it level. Drill two hole in the top like in step three. Take the clamps and screws off and finish gluing. Make sure to put all the screws back in the holes.
Step 5:
Put plugs in all the holes and apply wood patch to all the scratches, rough spots, etc. Once the Wood patch is dry, sand it all smooth.
Step 6: Make the Tabletop
Glue up a piece of 3/4" walnut that is a little bigger than the inside of the top. Trace the exact shape onto the walnut and cut it out to the rough shape. Sand the edges to the exact shape. It should fit somewhat snug so there are no gaps. Once it is the correct shape, glue it in place. Make sure the walnut is even with the 2x4.
Step 7: More Sanding
Put wood patch in the gaps on all three sides of the walnut panel and sand it once it's dry. Sand the rest of the table until it is nice and smooth.
Step 8: Finishing
Apply polyurethane finish to the whole table. It doesn't really matter what you use, but natural oils might not be the best for durability. Follow the directions for whatever you decide to use.
Step 9: Done!
Great! Now you have a nice, modern end table. Its not just any end table, though. It can slide over your couch as a snack or computer table. If you make one, post a pic. I would love to see it. Happy making!
Step 10: Update
I decided I wasn't very fond of the 2x4 and painted it white. It looks much nicer than the plain 2x4. Also, it will hold as much as any other end table. I got lot of comments about whether it could hold weight or not. I tested it with a lamp , a Bible and my tablet, as said in one comment, passed with flying colors. There was no sag or tilt at all.
Runner Up in the
2x4 Contest
Leftovers Challenge
91 Comments
2 years ago
Very nice. I'm currently working on this. What is the best way to attach the leg to the bottom frame? I did two pocket holes and a single from the front. It seems to still be a bit loose. I also noticed you did one single screw on the top of the leg to attach to the top frame. Does that seem to be enough support? Thank you
Question 4 years ago on Step 6
Does the pdf download (a paid option) have the details on all the angle cuts?
4 years ago
Nice job isaylor. I have some leftover 2by6s and some walnut. I will try this IMMEDIATELY!!
6 years ago
Nice design and pics. I will attempt to make it this weekend and post a pic. Wish me luck!......THX
7 years ago
isaylor, great job on the table. Your instructions and pictures will make it easy for anyone to build a table. Any tips on maintenance of the table? Good luck in the contest.
Reply 7 years ago
Thanks! For maintenance, just check every so often for sag. Good luck to you in the contest as well!
7 years ago
Absolutely love this! Thank you for posting.
Reply 7 years ago
Thanks!
7 years ago
This is so beautiful! And all of your steps are very clear and concise. Nicely done.
Reply 7 years ago
Thanks!
7 years ago
Me again, as I read my message to you it might not have been clear as to what opening I was referring to--I meant where you used the walnut wood. Thanks so much :)
Reply 7 years ago
Thanks! The opening is 7 1/4 wide by 10 3/4 long.
7 years ago
Hi, I loved this very modern and chic looking table. This looks as nice as some in ALL MODERN, and IKIA that I've seen. I would like to know the size of the opening if you could provide that to me, I would appreciate it. As others have said, and I agree...Very Well Done !!!
7 years ago
I absolutely love this! Simple, clean style yet functional.
Reply 7 years ago
Thank You!
7 years ago
very cool. simply funcitionial and beautiful
Reply 7 years ago
Thank You!
7 years ago
I love it. I'm always looking for ways to use up my offcuts. This is an awesome contemporary, simple design. Nicely done.
Reply 7 years ago
Thanks!
7 years ago
Brilliant! So simple and totally awesome! 5 stars :D
