Introduction: 3 Lamp Shade With Numerical Representations
In this project, using grasshopper, I made the lamp shape with numerical representations of the surface.
Step 1: Programming With Grasshopper
In the python code, to make the shape of the lamp, I changed the following part of the program from Jennifer's example code.
# Anzu's original geometry_Spherical Surfacesdef paramsurfD(u, v):r =(1+0.1*math.cos(10*(u+v)))x = math.cos(u) * math.cos(v)*r*sxy = math.sin(u) * math.cos(v)*r*syz = math.sin(v)*r*szreturn geom.Point3d(x, y, z)
These parts are for rendering the shape.
# Create mesh with geometry point information.u = u0du = (u1 - u0) / float(nu)v = v0dv = (v1 - v0) / float(nv)i = 0j = 0k = 0ms = geom.Mesh.CreateFromPlane(geom.Plane.WorldXY, geom.Interval(u0, u1), geom.Interval(v0, v1), nu, nv)v = v0for j in range(0,nv+1):u = u0for i in range(0,nu+1):ms.Vertices.SetVertex(k, paramsurfD(u, v))u = u+duk = k+1v = v+dvms.FaceNormals.ComputeFaceNormals();ms.Normals.ComputeNormals();a = ms;plu =[]plv = []v = v0j=0i=0for j in range(0,nv+1):u = u0pl = geom.Polyline()for i in range(0,nu+1):pl.Add(paramsurfD(u, v))u += duv += dvplu.Add(pl)u = u0;j=0i=0for i in range(0,nu+1):v = v0pl = geom.Polyline()for j in range(0,nv+1):pl.Add(paramsurfD(u, v))v = v+dv;u = u+duplv.Add(pl)b = pluc = plv
The output of the mesh data is processed by OffMesh to make offset and create solid. Msh2Psrf converts from the mesh data to a nurbs poly surface.
Step 2: Shape of a Lamp
This is the shape of the lamp created by Step 1.
Step 3: Calibration With Actual Size of the Lamp
To connect with the actual existing lamp, I made the connecter of the lamp shade first and check the connection.
The connecter fits well with the lamp. Therefore, based on this connecter, I adjusted the size of the lamp shade model.
Step 4: Slice Lamp Shade With Cura
The estimated print time is 6 hours and 51 min. I used preview to see each slice if this lampshade model was processed without any problem.
Step 5: Done!!
This is the 3D printed shape of the lampshade. It connects with the existing lamp, and it is lighting like this picture.
Step 6: Cloud Shape
We can make other numerical representations of the surface.
In the part of python code, we can change it like this.
def paramsurfD(u, v):r =(1+0.1*math.cos(10*u)*math.sin(10*v))x = math.cos(u) * math.cos(v)*r*sxy = math.sin(u) * math.cos(v)*r*syz = math.sin(v)*r*szreturn geom.Point3d(x, y, z)
Step 7: Bumpy Cylinder Shape
def paramsurfD(u, v):r =(1+0.1*math.cos(10*(u+v)))x = math.cos(u)*sx*ry = math.sin(u)*sy*rz = v*szreturn geom.Point3d(x, y, z)
Step 8: Hemi Spherical Surfaces
def paramsurfD(u, v):r =(1+0.1*math.cos(10*(u+v)))x = math.cos(u) * math.cos(v)*r*sxy = math.sin(u) * math.cos(v)*r*syz = math.sin(v)* math.sin(v)*r*szreturn geom.Point3d(x, y, z)
