3 Ways to Make a Smoke Bomb
19,665
10
Introduction: 3 Ways to Make a Smoke Bomb
1st way to make a smoke bomb:matchsticks
It is very simple to make a smoke bomb with matchsticks Just take one full box of matches and a duct tape. First take your box of matches. Now open the box and tap it on the ground so the match sticks are lined up, then place the striker inside the box facing the match heads and now take the tape and the box and tape it tight. Use a lot of tape , tape it length and breadth wise, around the sides and you must tape diagonally.Do not tape it fully. When used enough tape when the corners aren't pointy and the box feels cushioned. Now all you have to do is go outside and peg it hard at the ground and Rock on!
2nd way to make a smoke bomb:ping pong ball
Start by poking a hole in one side of a ping pong ball.Keep working at the hole until it's large enough to insert the pencil into it. Put the pencil in the ping pong ball.Wrap aluminum foil around the ball and the pencil. Don't completely cover the pencil. What you're doing is making a nozzle for the smoke, so work an inch or two up the pencil.Remove the pencil. The ball plus foil is your finished smoke bomb!Take the smoke bomb outside and use a lighter flame to heat the foil on the bottom of the ping pong ball until smoke starts to come out of the nozzle. Set the smoke bomb on the ground and Rock on!
3rd way to make a smoke bomb:
Buy potassium nitrate.Get some sugar.Pick up some baking soda and add a tablespoon.Get a small length of fuse.Obtain a cast iron skillet.Prepare a cardboard box lined with aluminum foil.Measure out three parts potassium nitrate to two parts sugar.Heat the pan slowly over low flame.Add one spoonful of baking soda.Pour the mixture into the cardboard box.Insert a fuse while the mixture is still soft.Let the mixture completely harden.
Set up the smoke bomb in a safe place outdoors and burn it.rock on
YOU CAN ALSO VISIT BELOW YOUTUBE LINKS FOR MORE DETAIL:
1.
2.
3.
Step 1:
Be the First to Share
    • Frozen Treats Speed Challenge
    • Electronics Contest
      Electronics Contest
    • Digital Fabrication Student Design Challenge
    3 Comments
    The_Modder
    The_Modder
    4 years ago
    also where do u get potassium nitrate
    Yash Dutt
    Yash Dutt
    5 years ago
    please give comments
