Introduction: 3D KEVA Challenge 2: Bed
Welcome to 3D KEVA Challenge! Are you up for it?
Each 3D KEVA Challenge will present the learner with a set of 3 views (Top, Front, and Right). Using these views alone the challenge is to position your KEVA Planks in a way that matches the views.
A single KEVA Plank has been placed on the workplane for you to get started. (need part to prevent scaling)
When ready you can check your solution to confirm your build was successful.
Instructions
- Review the challenge image above.
- Use the plank provided on the workplane to complete the challenge.
- Copy and paste or duplicate the existing plank. Create as many planks as you need to complete the challenge.
- Move, rotate, or change the color of your planks to help with the design.
- Continue to the next step get started with your guided build.
Step 1: Start With 3 Planks
Create a couple more planks and position them on the hints.
Instructions
- Copy and paste two additional planks.
- Move each shape into position using the hints as a guide.
- Review your work to see if any of your planks are out of position.
- If you find any planks out of position, take some time to reposition them now.
- Continue to the next step for the hint.
Step 2: Keep Up the Good Work.
Create two more planks and position them on the hints.
Instructions
- Rotate the planks to match the hints shown.
Step 3:
Instructions
