Introduction: 5 Simple Rubber Band Life Hacks
If you have a bunch of rubber bands and no idea what to do with them, you’re in luck! Try some of these rubber band hacks, and you’ll see just how handy they are.
Jump into any section:
(00:12) Remove a Stripped Screw with a Rubber Band
A rubber band may provide enough grip to remove a stripped screw. Place a wide rubber band in between the screwdriver and the screw, then apply hard, but slow force as you turn.
(01:11) Bind Pages Together with a Paper Clip and a Rubber Band
The method is pretty simple. You make two holes in the pages (if they aren’t already there), loop a rubber band through the holes from the back of the pages, and attach each end of the band to each end of a paper clip.
(02:25) Open Stuck Jars with Rubber Bands
It’s a simple trick. When you’re faced with a lid that won’t budge, just wrap a rubber band around it several times to give you a better grip.
(02:57) Keep a Door from Locking when You Out or In
Wrap a rubber band around the knobs. After wrapping it on one side, twist the band to create an overlap and wrap it around the other knob. This will create a buffer and the door will not lock.
(03:35) How to Prevent the Breaking of a Charging Cable
Learn how to reinforce your charging cable in order to avoid its breaking. You will need a drinking straw and a rubber band.
Please leave your comments in the comments section.
Your feedback will be appreciated.
Thanks for watching!!
Like ! Share ! Comment ! Subscribe !
