Introduction: 50 Cent Slushy
supplies
2 bowls
water
beverage
This is the 50 cent slushy only using a freezer and the supplies above
Step 1: Two Bowls
Get 2 bowls or cups one larger than the other.
Step 2: Preparation
Put the smaller bowl/cup into the larger one then fill the remaining spaces with water.
Step 3: Freezing
Put saran wrap over the 2 bowls/cups.
Step 4: Now Freezing
Put the bowls into the freezer. (Bowl in the freezer for 5hrs or until frozen)
Step 5: The Drink
Pick your beverage that you wish to turn into a slush and put it into your freezer. You want to leave it in the freezer for about 3 hours, and take it out before it starts showing signs of becoming a solid.The objective is to freeze it to the point that it is still a liquid but if you drop an ice cube it will be cold enough to freeze.
Not all drinks may work but some that do are sodas, sports drinks, water, and certain juices. Not all refrigerators are the same so you should play with the timing and see what works for you.
Step 6: Done Freeze
When the 5hrs is over take the ice cup out of the freezer and remove the cups from the ice. The cup may stick to the ice and to remove it add water into the small cup and around the big cup to take the cups off.
Step 7: Finish
Then you pour out you drink into the ice cup and it should start forming into a slushy.
