A Good Use for an Old Phone Charger
23,416
39
25
Introduction: A Good Use for an Old Phone Charger
About: I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my first to…
Indoor/outdoor thermometers are handy, but the outdoor transmitter can consume too many batteries, depending on the unit. I decided to power the outdoor transmitter with an old phone charger. The voltage of the phone charger needs to be dropped about two volts to match the requirements of the transmitter. This Instructable is really about altering the voltage output of an old 5 volt switch mode phone charger to fit special power needs you might have.
I powered up the transmitter for this thermometer with some partially used AAA batteries. Notice the battery with a diagonal line through it on the upper half of the display. This is a weak battery symbol.
Materials
  • Switch mode phone charger with a 5 volt, 0.5 to 1.0 amp. output
  • #24 speaker wire
  • 1N4001 diodes
  • Brass sheet
  • Electrical tape
  • Solder
  • Dowel rod
  • Staples for doorbell wire
  • Mounting screw
Tools
  • Multi-meter
  • Soldering iron
  • Heat sink
  • Side cutter pliers
  • Knife or wire stripper
  • Wood saw
  • Precision Phillips screwdrivers
  • Toothpick
  • Jumper wires with alligator clips
  • Hammer, etc. for mounting wire and transmitter
Step 1: Phone Chargers
These are only two of our collection of old phone chargers for phones we no longer use or have.
The output on these is typically very close to 5 volts at 0.5 amp. to 1 amp. In order to power the outdoor sender unit on my thermometer I will need to drop the voltage to about 3 volts.
Phone chargers are switch mode power supplies. I once tried to reduce the voltage on a switch mode power supply using an LM317 variable voltage regulator chip. It did not work. The power supply shut down until I removed the regulator chip.
Step 2: Dropping the Voltage
In theory it should be possible to drop the voltage appropriately using resistors. But, power dissipation (wattage) becomes a consideration in addition to the number of Ohms needed, and that is a problem. With 1 amp. flowing the correct resistance to drop the voltage by two volts is 2 Ohms, but that resistance needs to be able to handle 2 Watts and most common resistors are rated at 1/4 or 1/8 Watt.
Common diodes, like a 1N4001, are not expensive, can handle 1 amp., and can drop a voltage flowing through them. I have read that each diode is supposed to drop the voltage 0.6 volts, but a test with a multi-meter shows the voltage drop to be about half of that. Six* diodes dropped the voltage from 4.97 volts to 3.13 volts. (Note: I had three multi-meters available and got a different reading on all three. The difference between the highest and the lowest was 0.7 volt for a high reading of 3.79 volts. See the second photo. I compared the thee meters by reading the voltage across the batteries where the current enters the transmitter unit. Under a load situation like this all three meters were very, very close to each other. I decided the circuitry of my "best" meter was interacting somehow with the anomalies of the switch mode power supply. The cheap little Harbor Freight meter gave the best reading in this situation to my surprise. When I removed the batteries and connected the phone charger with added diodes, the transmitter worked as it should.)
See the third photo. My diodes have been rolling around in a plastic storage tray for quite a few years. The band indicating polarity is all but gone. I used the diode test function on the multi-meter to identify the polarity of the diodes. I used white fingernail polish to mark them for my own benefit. The breadboard was a big help for getting this experiment set up right.
*After my improvised power supply had run for a few minutes to power the outdoor sender unit, the low battery symbol appeared again on the base display. I shunted one of the diodes with a jumper wire soldered in place, and the low battery symbol disappeared. The signal from the transmitter was also stronger and the reading from it on the base display was less likely to disappear, especially when it had to travel across the house through more walls and distance to the room where we prefer to have the display.
Step 3: Solder the Diodes in Place
I want to run a low voltage wire from a wall outlet inside my garage through a crack in the door jamb to the outdoor sensor on the shady side of the house. I spliced the wire from the phone charger to a piece of moderately heavy speaker wire. I removed sections of one conductor and inserted the diodes one at a time. There is some wire between the diodes so the wire is more flexible for necessary bends. Notice the spring clip heat sink. Diodes are very sensitive to heat. Always use a heat sink when soldering diodes and other semi-conductors.
After soldering each diode in place I checked the current flow through the last two diodes using the diode test function to be certain I had not made a mistake. I wrapped the wires in plastic electrical tape when I was finished soldering and testing.
Step 4: Dry Run
I wanted to be certain my modified phone charger would power the transmitter unit. I connected jumper wires from the speaker cable to the input terminals inside the transmitter. Pay attention to where the tip of the battery would be and where the blunt end of the battery would be, or you will have the polarity reversed and the transmitter will not work.
With four terminals available, you may wonder which two are the input terminals. Two are simply a jumper that connects the ends of the batteries to each other, and there will be no voltage at those two terminals. See the second photo. Compare the second photo in the step 2.
Step 5: Make Connections to the Battery Bays
I cut a thin strip of paper and fitted it just like the thin brass you see here. Then I used it as a pattern to cut the thin brass. I made dummy forms from 3/8 inch wooden dowel rod. See the second photo. One of the dowel ends needs a point on it similar to the tip of a battery so good contact will be made with the terminal inside its recessed area.
Step 6: The Other Connection
The photo shows another paper strip for sizing the second brass strip. The first brass strip is in place and held securely by the dowel battery dummy form. These thin brass strips will allow me to run conductors to the outside of the transmitter without chewing out part of the case the size of a speaker cable.
I already learned each time I tamper with the power to the transmitter I need to press the reset buttons on the transmitter first, and then on the display unit inside the house. The transmitter reset requires the removal of three small screws easily lost when working on a ladder near where the transmitter will be located. I measured carefully and drilled a hole through the back of the case so I can push the reset with a toothpick, and without removing the three screws. Even though the transmitter will be under the eaves and protected from weather, I will put a piece of electrical tape on the back to seal the hole during normal operation.
Step 7: Test
I connected jumper wires to the brass strips and to the leads for the phone charger with the diodes added. The wider strip is the negative (-) side. The transmitter works. After resetting the transmitter and the display unit, everything worked as it should.
Step 8: Almost Done
As you can see the transmitter is working with power from the modified phone charger and no batteries. The low battery symbol has disappeared.
The outside reading is higher than the inside reading because the transmitter is not yet mounted on the outside of the house. Rather, it is on a dining table under some incandescent lights where I have been working on this project. What remains to be done is to run the speaker cable through the crack in the garage side door and staple it neatly in place. Then I need to mount the transmitter under the eaves of the house and solder the ends of the speaker cable to the brass strips. I will need to press the reset on both units and then all should be good. (If we lose power to our house, I will need to follow the reset process again.)
I have some partially used AA batteries my wife would like gone from our refrigerator. Eventually I will modify another old switch mode phone charger to power the inside unit, as well.
Some phone chargers shut down momentarily. You may want to add a smoothing capacitor with a value of 1000 micro-farads, or so.
Step 9: Other Uses for an Old Phone Charger
I have a CD/MP3 player that I could easily power with another reduced voltage phone charger and two wooden battery dummies. I have a Walkman type AM/FM radio/tape player I sometimes keep on my nightstand in case I am awake and want to listen until I fall asleep again. I even have the right male power jack for the 3 volt input jack. I could power it from a modified phone charger, too. If I needed a 4.5 volt power supply, I could tap into the string of diodes for 3 volts to get close to the right voltage for something with that power requirement. A small resistor could be used to dial in the power supply's output to just the right figure. The amount of power dissipated by a small resistor to bring voltage down from 4.7 volts to 4.5 volts at even 1 amp. is less than 1/4 Watt and would not overheat the resistor.
The photo shows another use for an old phone charger. So many of our current devices can be powered through a USB cord. The output of a switch mode phone charger is exactly what USB devices require. As long as the phone charger is of a good quality and not excessively cheap and "noisy," you can attach the female end of a USB cord and have an extra portable USB charger. Save the male end and attach it to something, like a small iPhone or iPod speaker so it can be used with AC power instead of batteries that cost money, need replacement, and become waste for disposal.
Be the First to Share
    • Make It Bridge
      Make It Bridge
    • For the Home Contest
    • Big and Small Contest
    25 Comments
    RincewindT
    RincewindT
    7 years ago
    Hello, you mention you can add a USB female to charge other phones. I have tried this and gone through 3 old chargers that said they were 5v but un reality were at least 6v. Any thoughts? Lost cause or I can step it down easily without making too cumbersome when travelling. Thanks for the instructable!
    Phil B
    Phil B
    Reply 7 years ago
    Thank you for looking and for commenting. Two things are important to your question. One is that some charger power supplies are better regulated than others and produce an output voltage closer to the specified voltage. The other is that you are probably sampling a no load voltage. The voltage often drops to near the specified voltage when a load is connected to the power supply. I might also add that the parameters on required voltage for a device often are not so exact as we might think, but some latitude may be allowable.
    vvm8485
    vvm8485
    7 years ago
    My son has a battery operated microscope which uses 2 AA batteries. We wired up to a phone charger with a input of 100-240vac. It worked for a few minutes and the light blew. We replaced the bulb and the same thing happened. Is the charger to strong for the microscope. Thank you!
    Phil B
    Phil B
    Reply 7 years ago
    Despite the input voltage, what is the charger's output voltage? If it is a phone charger, the output from the charger is probably around 5 volts. Add five or six diodes in series and check the output.
    I am guessing the bulbs are incandescent. I expect six or seven diodes in series should reduce the voltage output to what the bulb handles well without burning out.
    Perhaps you have already made the charger work as y wish it to work.
    Thank you for looking and for commenting,
    AksharaR
    AksharaR
    7 years ago on Introduction
    hi mr. phil. is there any intructable uv made or could u please make one or could you pl write to me on my email id akshararathode@gmail.com "how to connect a mobile directly to power plugs without need of a Battery. coz im on a project where i have to put the mobile on 24/7 for many days at a stretch which i cannot do if a battery is involved as it will heat up....or is there a way to protect the battery if i put the mobile plugged in all the time ....plzzzzzzzz guide me quickly. im in an emergency
    Phil B
    Phil B
    I would plug a phone charger into the phone, but I would put 1000 microfarad capacitor across the positive and negative leads. Chargers sometimes cut out and the capacitor would smooth that out. I am not sure if you can bypass or remove the battery.
    carlos66ba
    carlos66ba
    9 years ago
    Gotta love these Harbor Freight multimeters!
    Phil B
    Phil B
    Yes. I never expected I would.
    You must have hit something a couple of extra times because the site was not responding. I see three copies of your comment. You could remove two of them, if you wish, unless you posted extra times for emphasis. Thanks.
    carlos66ba
    carlos66ba
    Sorry! Sometimes the instructables android app misbehaves. I have removed the extra ones. I do like these, but not to the point of writing 3 times the same, LOL!
    Phil B
    Phil B
    I figured it had to be a software abnormality. Thanks for getting back and fixing it.
    rimar2000
    rimar2000
    Good instructable, Phil. I think in all homes in the world there are MANY disused phone chargers, of many different types. I usually write on them with liquid paper their voltage and amperage to avoid having to walk with a magnifier glass everytime i need to try a little motor, a lamp or something so.
    Phil B
    Phil B
    I hope this is helpful for people who have many old chargers, do not want to put them into the garbage because they seem too valuable to discard, but do not know what to do with them, either. All of the phone chargers I have seen are 5 volts. Some other chargers or power adapters are 6 or 9 or 12 volts, maybe even other voltages. I always need a power adapter with an output voltage different from what I have available. I was looking for a way to change the output voltage of the switch mode power supplies. I expect others can use this too, especially since I could not make a variable voltage regulator chip work with a switch mode power supply. Thank you for looking and for commenting.
    Phil B
    Phil B
    Thank you for the link, Osvaldo. I understood what the man in the video did. I would have wanted to wear rubber coated gloves to do what he was doing. Here is a similar video. I would not want to do this, either.
    rimar2000
    rimar2000
    It is not as dangerous as seems, Phil. During many years (30+) I used at work a cup water heater made with two battery carbons or two stainless steel strips connected directly to 220 V. Sometimes a coworker worried about my security, and to evidence the device I immersed my finger into the water, without get/feel any electricity. Even if the container is metallic, the current goes between electrodes only. The only caution that always I took was don't touch the wall or the floor, so avoiding to make ground. You could do a try, you will not suffer any hurt. You could do a try, you will not suffer any hurt. I think that even cardiopatas are safe using such simple device. However, I would not give it to a child, it is only for adults and moderately careful persons. I covered/protected the electrodes with a "rulero", it allows the water circulate but avoids short-circuit.
    Phil B
    Phil B
    Thank you for the education, Osvaldo. I very well understand the concept of not becoming part of the ground circuit. When I was young and still at home, my father did electrical work, mostly for the farmers who lived near us. Often they were getting a new, higher amperage service for the farm buildings. My job was to climb up the wooden pole in the yard, disconnect the old service, hang the new service, and make the connections. Sometimes I had to handle wires that were "hot" (not disconnected from the electrical transformer). I acted like a bird sitting on a wire. I touched only one wire at a time and did not touch anything that was grounded. Your heater for your cup of water would be a lot like welding under water. That appears to be frightening and dangerous, but must be quite safe, if done correctly.
    xcompass
    xcompass
    Great post. Depending on what's inside the charge, you may be able to drop the voltage just by adding a resistor. (though you need to open the charger) I used a resistor to dropped the voltage from 5v to 1.8v on the LM317 based charger for my shaver. It works great and that's where I learnt how to use LM317.
    Phil B
    Phil B
    Thanks. In my experience an LM317 works with a wire wound transformer, but not with a switch mode power supply like most phone chargers. As I mentioned, most resistors cannot handle the power that must be dissapated (Watts). That is why I used diodes to drop the voltage.
