Introduction: APPPAD
APPPAD V0.01 (Automated PDF Portable Print Assist Device) SRNHS SY.2024
DIY: Turn Your Old Printer into a Smart Printer
Tired of having to use a desktop computer to print your PDF files? This project offers a simple solution - a device that allows you to print PDFs directly, without needing a desktop or laptop.
Think of it as upgrading an old LED TV to a smart TV. This device will transform your basic printer into a "smart printer" with enhanced capabilities.
It's designed to work with any printer that is listed on the OpenPrinting website (https://www.openprinting.org/printers) and lacks built-in USB support for direct printing from a USB drive.
NOTE: This project is dependent on the CUPS (Common Unix Printing System) driver on a Linux-based operating system, such as Armbian, to manage and utilize a printer. The project will not be functional without the CUPS driver integration.
The core of this project is a combination of an Orange Pi One and an Arduino Uno. This setup can read PDF files from a USB flash drive and send the print data directly to your printer. It's a straightforward build, focused on the key functionality of reading PDFs and sending them to the printer. PDF was selected as the supported file type since it's a common and widely-used document format.
The instructions provided are to show how to replicate and use APPPAD. Some additional instructions will be provided as links.
Parts Needed:
- 1x Arduino Uno R3
- 1x Orange Pi One
- 1x SanDisk 64GB Ultra MicroSDXC UHS-I Memory Card
- 1x Rotary Encoder Module
- 1x TFT Display 2.0 inch OLED LCD ST7789V 240RGBx320
- 1x RJ45 Male to Female Screw Panel Mount Ethernet LAN Network Extension Cable
- 2x USB 2.0 Male to Female Extension Panel Mount Extention Port Cable
- 1x ORICO TWU3-4A 4 port USB Hub
- 1x Orange Pi USB to DC 4.0MM - 1.7MM Power Cable
- Jumper Wires/Dupont Wire Cable
Step 1: Connect Rotary Encoder Module to Arduino
ROTARY ENCODER ---> ARDUINO UNO
GND ---> GND
5V ---> VCC/5V
S1 ---> D7
S2 ---> D4
KEY ---> D2
Step 2: Interfacing an ST7789V Display With Arduino
ST7789V ---> ARDUINO UNO
VCC ---> 3.3V
GND ---> GND
SCL ---> D13
SDA ---> D11
RES ---> D9
DC ---> D10
CS ---> D8
Step 3: Attach Ethernet Network Extension Cable to Orange Pi One
Step 4: Flash APPPAD Image to an SD Card Using BalenaEtcher
Download the image file from Google Drive
Go to the URL:
https://drive.google.com/file/d/1IEGoToK269D72-QhtN7JMqiFEmdGGgR8/view?usp=sharing
Install and use balenaEtcher to flash the image to an SD card.
Download the balenaEtcher application for Windows.
Go to the URL:
Install and launch the balenaEtcher application.
In balenaEtcher, click "Select image" and navigate to the apppad_sandiskUltra_64gb.img.gz file you downloaded from Google Drive.
Insert the SD card you want to use. Make sure to use a 64GB SD card like the 'Sandisk 64GB microSD High Endurance'.
You may need to use a card reader like a '4-in-1 USB Flash Card Reader Memory Card Reader' to connect the SD card to your computer.
Click "Flash!" to start the process of flashing the image to the SD card. (IT TOOK US 45 MINUTES TO FLASH!!)
Use the flashed SD card.
Once the flashing process is complete, remove the SD card from your Card Reader.
Insert the flashed SD card into your Orange Pi One device.
NOTE: You also can also follow the same procedure from this video:
Step 5: Connect All USB Peripherals to ORICO USB Hub
Step 6: To Supply Power on APPPAD
We can use any 5V 2A powerbank to power APPPAD.
Step 7: Using the EPSON L120 Series
Connect the Printer: Before turning on APPPAD, first plugin and connect the EPSON L120 Series printer. Ensure the printer is properly plugged into a power source and that the USB is securely connected.
Once the printer is connected, you can proceed to turn on APPPAD. The printer should automatically be detected and the necessary drivers should be loaded.
Access Printer Settings: To adjust the printer settings, you can access the printer's web-based interface by navigating to its IP address on port 631 using a web browser. This will allow you to configure various printer settings, such as paper size, resolution, and other preferences.
Note: Please note that these configurations are specific to the EPSON L120 Series printer and may need to be adjusted if you are using a different printer model. We cannot guarantee these instructions will work on other printer models, as we have only tested this setup with the EPSON L120 Series printer.
Step 8: Example of How to Add a Printer
Make sure that APPPAD is connected to your router and your printer is connected to APPPAD before proceeding with the setup. Then turn ON APPPAD.
For instance, if the IP address shown on the screen is 192.168.2.104, open a web browser and type in the address bar
192.168.2.104:631
This will allow you to browse the configuration of the device.
username
admin99
pass
grp3ste
Step 9: Set the New Printer As the Default
After the new printer has been added, you should see it listed in the "Printers" section.
Step 10: Accessing Files on the Network
If APPPAD is connected to the router, you can access the files by using the Windows File Explorer. You can browse the files by navigating to the IP address that appears on the screen.
For example, if the IP address displayed on the screen is 192.168.2.103, you can access the files by going to the following path in your Windows File Explorer:
\\192.168.2.103\admin99
username
admin99
pass
grp3ste
Arduino Source Codes
\\192.168.2.103\admin99\apppad_c
Python Scripts
\\192.168.2.103\admin99\apppad_py
Step 11: Unplug Ethernet
Once you have finished setting up the printer, you can disconnect the APPPAD from the network by unplugging it from the router.
Step 12: Ready to Use for Printing
You can now use this device to print your PDF documents directly from USB flash drives. However, you should avoid using USB external hard drives, as they require a high-powered USB power source that this device may not be able to provide.
This device has a convenient feature that automatically prints your PDF document if it finds only one file on the USB flash drive. If there are multiple files on the drive, you will need to use the menu options to select the file you want to print.
Step 13: Thank You!!
Thank you for taking the time to read the how-tos of this project. This innovation will help extend the capability of old printers, allowing users to conveniently print PDF documents directly from USB flash drives without the need for a desktop computer. It's a simple yet powerful addition that can breathe new life into aging printer hardware.
