Introduction: Alexa Echo + ESP 8266 = Smart Power Plug
This instructable use ALEXA ECHO direct control ESP8266.
My server just support authorization ESP8266 to Amazon server.
My server do not backup your data.
Vote for me :D Thank you!
Step 1: Requirements
HARDWARE
ESP8266 WiFi 5V 1 Channel Relay Delay Module
https://www.amazon.com/WHDTS-ESP8266-Channel-Trans...FTDI USB to serial module (not required if use nodemcu)
https://www.amazon.com/Qunqi-FT232RL-Serial-Adapter-Arduino/dp/B014Y1IMNM- Amazon Echo
- Male and female power plug
SOFTWARE
Step 2: Flash New Frimware
1. Unplug ESP8266 from module
2.Connect module to USB to Uart module:
GND -------- | GND TX | -------- RX
------- | IO2 EN | -------- 3V3
GND ------- | IO0 RST | -------- BUTTON -------- GND
TX ------- | RX 3V3 | -------- 3V3
BEFORE FLASH, PRESS BUTTON TO RESET
(IO0 alway connect to GND -> ESP8266 goto flash mode after reset)
3.Flash my firmware
- Download my sketch:
- Open in Arduino IDE, and change:
- wifi_ssid: your wifi name
- wifi_password: your wifi password
- control_password: your secret password
- friendlyName: your device name
- ip/gateway/subnet: ESP8266 IP static for NAT
- Board: Node MCU 0.9 ()
- Upload Speed: 230400
- Port: Select your USB to Uart port
4.Connect ESP to module again
5.Connect power plug
Step 3: Config NAT & DDNS
We need open port (default 666) to control from Amazon server to our ESP8266.
I just illustrated with my router. You can find out how to open your router port on the internet and open TCP port 666 to the configured ip in step 2
https://m.wikihow.com/Open-Ports
if you do not have a fixed ip. You must use a dynamic domain name. You can find many free DDNS service providers.
Step 4: Control by ALEXA ECHO
1.Enable my skill named "ESP8266 Smart Power Plug
- Alexa app > Select menu > Skill
- Search Skill named "ESP8266 Smart Power Plug"
- Click to Skill
- Click ENABLE
- Login with your Static IP or DDNS domains (include your port - default 666)
2.Discover device
Alexa app > Select menu > SmartHome
- Click Add device and wait 20 seconds
- Now you can see ESP8266
3.Control:
"Alexa, turn on/off <your ESP named in step 2>"
Runner Up in the
Voice Activated Challenge
Arduino Contest 2017
Remote Control Contest 2017
1 Person Made This Project!
- mharmon12 made it!
19 Discussions
Question 10 months ago
Trying to add skill to my alexa but not available at Spain. Is it posible to take a look at your skill code. I'm trying to build a watering system using esp8266 and want to activate/deactivate watering and have enviromental data from sensors. If not posible, could you make the skill available to Spain?
1 year ago
This is a great demonstration!
I implemented with ESP-01 and works with Echo Dot and all of the Amazon Smart Home functionality through cell phone and web interface.
Where did you learn this from?
I would like to make changes so it refreshes the current state with Smart Home.
Great job!!!
Mike
Software Developer
Meridian, Idaho, USA
23 November 2019
Reply 1 year ago
Thanks Mike
Question 2 years ago on Introduction
is there a way to have the power cord power the relay.. like a sonoff? so you only one cord.. instead of two?
Answer 1 year ago
I'm guessing that is beyond the scope of this project.
Question 1 year ago
How do I set it to activate just one of the pins? i looked at your code, but I couldn't figure it out. I just want to power GI00 or Gi02, not the relay. Could you help me?
Answer 1 year ago
Look at the pinout for your device and then find the port for that pin in the device docs.
Question 1 year ago
Also, what am I supposed to do with the three IP address sections, right in the beggining, I was confused as to what I should replace them with.
Answer 1 year ago
Run IPCONFIG from the command line.
gateway = Default Gateway
subnet = Subnet Mask
ip = your ESP device. Usually, same as gateway with last digit changed.
It is assigned by your router.
2 years ago
hello, i can't find our Skill, i think it's dead :-(
Question 2 years ago on Step 4
Hi,
Good job !
Do you think it is possible to translate the skill into French? to control esp8266 in french?
Thanks
Answer 2 years ago
Ok, but I'm not really free now. Can you build one yourself?
Hi
Can you use multiple ESP8266 connected to Alexa?
Does your skill support another port forwarding or only 666?
Answer 2 years ago
Yes, you can change to another port on arduino code
3 years ago
Hi this looks really good but I cannot locate the Alexa skill you refer to
Reply 3 years ago
It now live. You can search it now :)
Reply 3 years ago
I just submitted my skill. It may take a few days for you to find it.
3 years ago
https://www.ebay.com/p/Esp8266-WiFi-5v-1-Channel-R...
$16.69
or
https://www.aliexpress.com/item/Itead-Sonoff-Smart...
$5.68
I'll use the Sonoff instead.
Reply 3 years ago
You can edit my sketch a bit. My relay controller module via uart. With sonoff you can be direct controlled by gpio
