Introduction: Another Insulin Pump Case
I promise not all my posts will be pump cases – it can just be extremely annoying when you have to have a beeper sized device on your person at ALL times, day and night. As a result, when I’m trying to come up with a project for this blog a better, more efficient pump case is always running through my head. I’m pleased with how this case turned out and I hope you like it as well!
For other projects similar to this, please visit my blog: Diabetic Hacker
Step 1: Ingredients
- Scrap fabric – Exterior and Lining
- Bias Tape
- Hook and Loop (Velcro)
- OPTIONAL – Embellishments (pictured is the lace and button)
Step 2: Cut the Pieces
- Main Panel 4″ x 6.5″: Exterior Fabric and Lining
- Sides 1.25″ x 1.25″: Exterior Fabric
- Pocket 1.5″ (NOTE: not 2″) x 4″: Exterior Fabric
- Belt Loops 2″x 1″: Exterior Fabric
Step 3: Prepare Pocket, Sides, and Belt Loops
- Stitch bias tape along the top of the pocket fabric to finish it (or hem)
- Stitch bias tape along two sides of each side
- Stitch bias tape along 3 sides of each belt loop
Step 4: Attach Hook and Loop (Velcro) Pieces
- Attach the hook and loops to the belt loops. I didn’t do anything super sophisticated here, as you can probably see. I just attached them near the bottom.
- Not Pictured (because I missed this step) Attach a hook and loop piece to the center bottom (side OPPOSITE of the bias tape) – addressed this missed step by simply gluing the piece at the end, however I would’ve been much happier if I had just sewed it when I should have.
Step 5: Attach Belt Loops to Main Piece
- Measure 2.25" from flap edge and pin in place
- Zig-Zag stitch across the unfinished edge of the belt loops, attaching it to the main piece
Step 6: Embellish (Optional)
- As always, I enjoy adding a little personalization to my projects.I stitched the lace along the top to tack it into place, and then hand stitched the button – go wild.
- Nerd it up if you like (see The Harry Potter – Slythern House snitch draft version below)
Step 7: Attach Belt Loops Hook and Loop (Velcro) Pieces
Attach the hook and loops (Velcro) pieces so that they match up with the belt loop hook and loops pieces
Step 8: Attach Pocket
Stitch the pocket into place: align the unfinished long edge with the bottom of the flap and stitch along the short edges and bottom, forming the pocket.
Step 9: Attach Bias Tape to Outer Edges of Main Pieces
As with many things, I can't claim to be an expert here, I more or less just wung it (winged it?). I SHOULD have started on the bottom as opposed to the flap, but it still turned out ok more or less.
Step 10: Attach Sides
- Stitch sides to main piece, aligning along the bottom with the bias tape edge up
- Mark 3.5" from the bottom with pins (on both sides)
- Fold main piece so that the top of the unattached side aligns with the pins from the previous step, stitch in place
Step 11: You're Good to Go!
The belt loops are not deep, but they are decently sturdy. You can attach them to a narrow belt, or you can sew an elastic band into a loop - which I've found great for sleeping/working out. You can attach it to bra straps, tank top straps, or you can simply sew a small strap to your favorite clothing items.
