Introduction: Awesome Paint/Spray Booth Hack (Small Space Solution)
Here's a hack that makes painting, spraying, or staining in a small space easier and more organized.
Read on to find out how!
*kiddie pool Height 3" inches
Width 8' feet
* Drill
*A general purpose bit- size 1/4" or similar
(If you don't have a drill use a hammer)
* 1 large diameter nail - for hanging project and making holes if necessary
* Strong nylon cord- sized to fit through holes drilled or hammered - 10" length or longer
* Waste board- at least 1/8" thickness and length - mine is 15" (the wood is used during drilling process to protect the work surface)
* Small Container with a flat base and flat top edge. The size pictured in this project is- Height: 10" and Width: 7 1/2 "
Step 1: Let's Get Started
•Drill or hammer 2 holes 3" apart in the underside rim of pool.
•Use waste board underneath to protect work surface.
•(To do this, drill or hammer stopping once contact with board is reached.)
•The board is reusable.
Step 2: Using Container for Spraying
Step 3: Elevating Project for Easier Painting
Step 4: Move the Pool Instead of Yourself!
The pool is lightweight and easily turns. You can access each area to be painted simply by using the rim of pool to turn it.
Step 5: Large Projects
Step 6: Storage Ideas
Step 7: ☆ Helpful Reminder ☆
Step 8: Storage
* Using your Heavy Duty Nail,
Store in a location out of the way.
Space saving and Organized.
*COOL!
Step 9: *Find Other Possible Uses Such As:
Gardening-
*Raking Leaves: drag it around with you as you rake leaves. Fill pool up. Drag to garbage. Dump.
*Weeding: easily move pool from spot to spot.
*Potting: Spill dirt? No problem. Dirt is contained and you don't have to sweep floor or lose precious dirt.
(Reccomend using a smaller size pool such a the one pictured.
Height 8" inches x Width 3' feet
this minimizes it getting too heavy to lift when filled)
Note: the smaller pool fits nicely underneath the larger pool when hung and not in use.
*Transportable: take on site. ie: helping out making decorations for Homecoming Parade
And! Of course, it's original use:
A KIDDIE POOL
Step 10: HAVE FUN!
Organization Challenge
