Introduction: Battery "free" Bike Light.
Step up and get your own "dynamo hum"...(FZ). All jokes aside, its a simple dynamo light mounted to a Planet Bike light bracket. On about 6 cranks I get 20 to 25 minutes of light.
There is a 3.6 volt NiMH rechargeable battery that comes in the light. SO, by free I refer to your out of pocket cost on batteries.
Step 1: Material
1. dynamo light....Harbor Freight, 2 for $8.
2. quick release light strap...most have a screw to change the mounting base, this is a Planet Bike
3. super glue
4. fingernail polish remover........or acetone
Step 2: Light Base
Remove the screw and discard the top thin portion.
Step 3: Level Base
Use a knife to take any high points off of the base.
Step 4: Break Light Down
Take the 4 screws out of light.
Be cautious not to let any gears or gear shafts to fall out.
Step 5: "drill" Hole for Screw
Using a hole punch I twist and push a hole through the plastic, working from both sides.
Step 6: Prep for Glue
Using the fingernail polish remover, I clean both surfaces.
Step 7: Glue
1. I put glue on the base only.
2. Screw light cover to base.
Step 8: Put It Back Together
Once glue is dry, put your 4 screws back in and your done.
Step 9: Get Rolling and Give It a Crank!
The law (here in Arizona) says you need a forward facing light visible from 200 yards. This covers that and I only need a rear red reflector. So, I'm now battery free!
24 Comments
13 years ago on Introduction
Awww!
I was hoping it would charge via the pedals or wheels...
Reply 6 years ago
In the 60s there was a light that worked from a power source that was mounted on frame and run the light from the tire.. Do not remember the name but I had one.
Reply 5 years ago
I believe what you are thinking of is a generator.
The end of he rotor rubs against the edge of the tire. Terrible tech. The faster you went the harder is was to pedal. Stick with batteries IMO.
5 years ago
I know this. Works perfect
6 years ago
Would that be a TL28 on the table
Reply 6 years ago
Good eye!
10 years ago on Introduction
i like it. This is going on my bike very soon
back @ you man!
No no no, you see, its a dynamo-charged rechargeable battery, so you do not need to replace them. Just crank the dynamo to recharge the internal batteries. This is pretty cool, now imagine if you attached a cable from the dynamo to your wheel! (hands free charging)!!
Reply 13 years ago on Introduction
Yeah, then you just have a normal light like found on about every bike.
Reply 12 years ago on Introduction
but the battery lasts soooo much longer.
Good instructable . Good not to have to worry about your batteries dieing on your ride . I do recommend having a cheap red blinky light for the rear it be seen much better then a reflector . In the same vein lights or reflectors on pedals make you much easier to see also .
NICE, anything not to purchase batteries!
Yeah, um these do have batteries, they just recharge.
Are you positive? I was told it was a capacitor.
Of course I may be wrong, and that's cool.
Yes, I've taken apart 10 or so of that kind of light. Each of them had lithium ion button cells.
Yes, you are correct.
Since it was featured, I'm not going to edit it.
It doesn't bother me if you edit it or not, I just like solving little misunderstandings and helping people understand how things work.
I thank you because I learned more about it......I went ahead and edited it anyways because it was wrong. I'm also new here and thought I could not edit once it had been featured.
Stay on point, please. I WILL do more stupid stuff in "public"!
Anyway, with or without battery, is an excellent instructable. And if there are batteries, but they are loaded by hand, are welcome.
