Introduction: Beebeecraft Tutorials on Making Small Daisy Earrings
Do you like to make handmade jewelry yourself? Yellow daisy earrings are really a bright color in summer. Do you want to do it by yourself? Let’s learn to make earrings with Beebeecraft.
Many people think that handmade jewelry is difficult to make. Actually not. In a laid-back afternoon or idle weekend, with your fingers, you can easily complete a handmade jewelry that is unique to you. Do not believe? Then let's take a look at the handmade earrings below.
Step 1: Supplies Needed for the Earrings:
Mixed Style Yellow Seed Beads
10~11mm White Glass Pearl Round Bead Strands
19mm Brass Earring Hooks
0.2mm Transparent Fishing Thread Nylon Wire
50mm Stainless Steel Head pins
40mm Stainless Steel Eye Pin
LightGreen Electroplate Glass Beads Strands
Steel DIY Jewelry Plier Sets
Stainless-Steel Scissors
Mixed Iron Sewing Needles
Step 2: Bead the Daisy of the Earrings
1st, slide a glass pearl beads to the middle of fishing thread nylon wire, and use another fishing wire to string the yellow seed beads, and pass the ends of the fishing wire through the holes of the pearl beads;
2nd, use another fishing wire to string some yellow seed beads and pass the ends of the fishing wire through the hole of the pearl beads too, let the yellow seed beads form a loop, and the pearl bead is surrounded in the middle;
3rd, insert the pin into the hole of the pearl bead;
4th, use pliers to cut off the excess of the eye pin, make a loop at the one side.
Step 3: Finish the Daisy Earrings
1st, make a loop at the one side of the broken pin;
2nd, slide the light green glass beads to a head pin and make a loop at the one side;
3rd, connect the two beaded dangle pattern and then attach a earring hook on the top of the dangle;
4th, repeat above steps to make the other one of the daisy earring.
Step 4: Now, This Daisy Earrings Have Been Finished:
Wow! this project is finished. Follow the steps of this article and bring your imagination, so you can get a special pair of daisy earrings. Don’t you want to have a try? No need any professional beading or wire wrapping skills, just follow this Beebeecraft tutorial, even you are a green hand, you can make a pair at home.
