Introduction: Beef Up the Assault Rifle in Halo 1
Now, the Halo 1 assault rifle may be one of the greatest weapons of all time, but sometimes I feel it needs a little more kick. To fix this problem, There are some easy steps to change the sound, reticule, accuracy, damage, and maybe even the look of this gun.
MAKE SURE TO BACK UP ALL MAPS!!!!!!!!!!!!>_<!!!!!!!!
Step 1: Open HMT
Ooen up Halo Map tools and find any map, single or multiplayer.
Step 2: Change the Sound FX
Once a map is open, select the [effe] Effects tab, and scroll down to find vehicles/warthog/effects/warthog gun fire, and copy the numbers in the box on the top left, otherwise known as the meta.
Then, find weapons/assault rifle/effects/fire bullet and copy the meta into the box. Press save.
Step 3: Increase Damage
Scroll Down to the [ipt!] damage tag, and select the weapons/assault rifle/bullet tag. Change the damage to the following:
Minimum Damage 20
Maximum Damage(Min) 30
Maximum Damage(Max) 30
Step 4: Increase Accuracy
Go to the [weap] Weapons tab and find weapons/assualt rifle/assault rifle. Scroll down to the bottom and click on the projectile bar. Select projectile 0, and set the min and max spread to 0.
Then, go back up to where it says zoom, and put in one of these two settings:
Zoom levels 1 or 2
Minimum Zoom 2 or 2
Maximum Zoom 2 or 8
DO NOT CROSS THESE TWO SETTINGS!!
Note:
There will be no zoom mask using either of these settings, it does not affect gameplay, but it will not look like a conventional zoom with parts of your field of view blocked. There will be a full field of view as usual, just zoomed in.
Step 5: Alter Reticle
Find the [bitm] Bitmap tag, and scroll down to find the ui/hud/bitmaps/combined/hud_reticles, and either save the texture and edit it yourself, or replace it with the file below.
Step 6: Change Texture
Find the bitmap for the assault rifle (weapon/assault rifle/fp/bitmaps/assault rifle_fp), which is found under the [bitm] bitmap section, and either replace it with the file below or save the texture and edit it to your own liking.
Step 7: The End!
The assault rifle has been beefed up, and should properly be called the combat rifle, being stronger and more combat ready.
36 Discussions
11 years ago on Introduction
Nice. Now you need to make it fire sniper rounds. Or Fuel Rod rounds. That would be interesting.
Reply 11 years ago on Introduction
Thats easy- Just swap the Projectile in the Projectile tab to what ever it is you want to shoot. Copy the meta from one and paste it into another, then press save. Check out the Frag Rifle, I made one shoot grenades.
i made the warthog turret shoot plasmas and if you throw a frag you throw a spartan
O.O You mean Plasma Grenades?
yes it is extremely devastating and useful if you want a pesky vehicle using killer (a guy that uses oly cars to kill) to quit
We're Not Pesky!!!
pesky or annoying ur choice
They are rather easy to dodge and plasma nade :P
true, but not if your sniping
If you are sniping you should be far enough away not to get run over :P
and also i need to know how to throw a spartan that you can control imagine throwing like 50 grenade then an army of spartans carrying assualt rifles that shoot rockets
I dont know how to add AI to a map, search around on halo forums for directions... I stumbled across and found an interesting idea, which was to make the pistol shoot camoflauge...
that is interesting hey do you still play halo PC
on occasion, yes
would you like o battle me eveantueally i am always on the server mod testing every now and then
Sure, why not?
ok so how about friday at 6:00 i live in the central time zone of the U.S.A. so you might be able to make that ur time not sure but i live in MOok tell me if ya want any other time
I wont be able to for a while, i'm pretty busy right now. I'll let you know when I have a chance.
ok but make sure not to forget
or rockets that would be devastating
