Introduction: Bent Wood Ipod Stand
This instructable is mostly about the wood gluing and clamping process. One you try it you will be able to use the method to make may beautiful projects.
I plan on making specific instructables of more projects I have done like lamps, fishing nets, tables, music stands etc. Don't be limited by straight wood- think out of the box into bent and twisted laminations.
Step 1: New Way to Clamp Bent Wood Laminations
Thin wet wood bends much better than dry wood. Thin wet wood can be easily bent into extreme shapes like springs and iphone stands. To keep the shape and make the piece as strong as necessary we laminate 2 or more pieces together. The problem is clamping. In the past it has been very difficult to clamp the a few thin strips together perfectly in the right shape. The woodbending book says to make two sided forms - difficult. Making 3d two sided clamping forms is impossible. A new glue-gorilla, stretch wrap, and an easy way to cut thin wood strips make my method possible.
We clamp the thin wood pieces flat with stretch wrap, then bend. Because urethane glue is slippery when wet, the thin pieces will slide over each other as they are bent. They stay stacked, and by using urethane Gorilla glue (sets up because of the water in the wood), you have about ten minutes to bend into the shape you want . Simple forms can be used to keep the wood bent properly. My largest project was a pair of wedding arches over 20 feet long- 2" x 3/4". I was able to make this by myself in two days. The smallest was a wood ring.
Strips as thin as 1/32" can be used, up to 1/4" thickness. Any wood can be used. Ash may be the best because it is both strong and bendable. Pine also works well, but only when wet. Most woods will bend when cut thin. You just cannot have any knots. If you don't have a tablesaw to cut the strips, you can buy 3/16" lath strips at home depot. You will probably have to sand these before gluing. If you want thinner pieces they are available from veneer suppliers or you can make your own if you have a band saw, or table saw with a fence feeder.
Here is how it is done. The video is worth more than all these words
http://www.youtube.com/watch?v=mO5iiaYeX4E
Step 2: Iphone Wood Dimensions
To make the iphone stand as I did, you can take the dimensions from the sketchup drawing below. If you are making a stand for a larger kindle or ipad , you will need larger pieces, and the bends will not be so tight.
I cut the ash wood pieces about 1/16" thick. I didn't have 1 1/2" wide wood, so I made the wide piece by gluing together the edges of two identically bent 3/4" pieces .
Step 3: Freehand Wood Bending
Stretch wrap makes a great clamp for laminations up to about 2" wide.
The wood is wrapped when flat and then the package of wood and glue is bent into shape. It can be held in the right shape in many ways. You don't need to clamp the whole piece, just enough to keep it from moving for 3 hours. A simple two dimensional clamping jig is a piece of plywood with screws placed where you want the bends to be. A stack of thin pieces wrapped in stretch wrap will take a very nice shape with very little support or clamping. You can also do three dimensional pieces like springs (wrap around a tube).
Remember, whatever you can bend one strip of wood to do, you can put a few of them together and keep that shape using the stretch wrap and gorilla goo.
Gorilla glue works outside so your project can be patio furniture, or a barbeque lamp. If you can dream it, you can make it. If you don't have access to the wood veneers, let me know and I will publish sources.
Step 4: Buying-cutting Thin Strips
Longer, wider pieces are found at woodworking/ cabinet supply houses and on the web.
You can cut your own if you have a band saw or table saw. The band saw leaves a lot of sanding to do.
To cut thr veneers is I cut them between the fence and blade, using a fence feeder and a zero clearance throat plate.
I used a $20, 7 1/4" blade and got a ready to glue cut . A video of cutting the wood is at:
http://www.youtube.com/watch?NR=1&v=pSO-hcVN4qk
If you use the tablesaw be sure to use a zero clearance throatplate because a thin strip will be pulled down into a large opening next to the blade.
The alternative cutting method requires moving the fence many times, cutting the thin pieces on the left side of the blade, but is the way to rip thin pieces if you do not have a fence feeder. Always use a push stick if you do not have an anti kickback feeder.
I suggest using a 7 1/4" thin kerf blade to save wood and sawdust.
Step 5: Gluing and Clamping Video
The glue has to be spread correctly as shown in the video. A tool with small notches like a hack saw blade works fine. Only one side needs to be glued, and not the top piece.
***Urethane Gorilla glue will turn your hands black for days- use the gloves. It does not come off easy like superglue.
The glue will start foaming after a few minutes , but as long as the wrapping is done by then, you will still have time to bend the wood.
The strips have to slide on themselves when bending, so the slippery glue works great in this application.
The edges of the wood will need to be sanded, so keep the pack lined up to reduce the sanding necessary. Just sand the poly off with the glue. The glue sands very easily, like balsa wood, and dries clear.
I finished with spray laquer, glued the two pieces together with a couple dabs of thick super glue and was done.
