Introduction: Easy Bicycle Panniers in a Developing Country
When I traveled in Peru with my bicycle I had planned on buying panniers in Lima. Even though cargo racks were easy to find, panniers were more expensive than they would have been at home. So I made my own using locally available materials (you can find these in any bigger city in Peru: Lima, Cusco, Arequipa, etc that has a SodiMac or other hardware store. The same holds true for most of Latin America.). They ended up being quite whimsical, easy to remove and sling on my back as actual backpacks again which is great for sudden bus or car travel (even though I got quite a few odd looks for my choice of children's bags) and held almost as much as regular panniers. They never caused me any difficulties and gave me quite a few laughs. But I think the local dogs were convinced I was abducting a creature on my wheel what with the ears on my one bag!
Our panniers were a hit with other bicycle tourers, too. You can find a description from some fellow bicyclists I met in Ollantaytambo here, about 3/4 of the way down the page: http://www.contoursofacountry.com/encounters/peru/
Step 1: The Goods
Pictured are the materials you will need for (1) pannier (one side). For both sides you need to double some of what is pictured.
- Backpack (2 for a set). The funnier, the better. Kids backpacks are $10-$15 in Peru, but you can find them much cheaper if you aren't as picky about them being "fun"
- Closet organizing shelf (2 for a set) (at least I think that is what it was, that was the aisle it was in). ~12"/30cm high $3. The point is that these should be at a bare minimum the height of the backpack. They prevent the backpack from getting sucked into the wheel, giving it a hard back.
- Mini, non-weight bearing carabiners, also known as clips. 2 for each side of the panniers (4 for a pair) $1 each
- Zip ties (get plenty, you might need more) $2 for a bag
- Scissors (for trimming straps and zip-ties)
- Optional: bin for the top, depending on what luggage you have $6
- Also optional but recommended: elastic of some sort. old tubes also work, you can add another carabiner to them. You might need these if your bags are too heavy and drooping down too much. $10 for elastic or possibly free for tubes
If you have scissors already and a few old tubes and aren't picky about how fun your panniers look, a set of rear panniers will cost you about $20-$25 (much cheaper than the $80-$120 they are in stores in Lima!). The materials can be found in Sodimac or the equivalent hardware store in Latin America (send your suggestions for other areas of the world!) and large supermarkets like PlazaVea often have deals on bookbags. You might even already have some of these things lying around or be able to ask for them on a networking website :)
Step 2: Clip the Pannier Frame to the Cargo Rack
This is pretty self explanatory. Clip the frame from the top of the cargo rack. Make sure it covers the top of the derailleur on the drive-train side, which might mean it doesn't hang perfectly vertical. That's ok.
Keep in mind that if you attach them too far forward, the bag might hang down where it could interfere with your pedal stroke.
Step 3: Zip Tie the Pannier Frame to the Cargo Rack
Once you have clipped the top of the frame to the rack, zip tie several points of it down to the cargo rack and possibly also add a point of attachment to the bicycle frame. try to get it so that the frame does not easily move. Then trim the ends of the zip ties.
The zip ties are difficult to see in this photo, but are clear colored. The ends have not yet been trimmed.
Step 4: The Bookbags
In order to attach the bookbags, you will likely need to cut the ends of the straps as depicted. This way you can take the top, padded portion of the strap and "weave" it through the pannier frame, starting at the top. You will then tie the padded portion and the non padded portion together, likely after looping the non-padded part through the pannier frame a few times for added security.
Tie the unpadded and padded portions together and trim any remaining excess strap beyond a few inches/8 cm
You might want to make sure the water bottle pockets are -not- on the pedal side, as with a large water bottle they might interfere with your pedal stroke.
Step 5: Check Everything!
Once you have attached both bookbags, check to make sure there are no loose ends that could get caught in your spokes. If you have a lighter, seal the ends of the bookbag straps so they don't fray from repeated dis-attachment. If you are going to be putting a lot of weight in your bags, see how that effects how they sit on the cargo rack, and maybe add elastic crossing over the top if they sink too much.
In the picture the bookbag straps have not been adjusted yet, and excess of the non-padded portion is still hanging down
Make sure you can ride the bike without the bags interfering with your pedal stroke. Now is the easiest time to make adjustments.
Step 6: Ready to Roll
Pictured are two complete bikes with handmade panniers, ready for a 4 day, 70+ km/day trek in Peru! The one in the front still had its bags attached 3 months of off-road use later, although they had a couple of holes and were not as vibrant anymore.
Pro-tip: the pannier frame plus cargo rack makes a great derailleur protector when traveling with your bike in a box on a plane.
18 Comments
9 years ago on Introduction
what a wonderful Instructable! This is quite possibly one of my favorite projects I've seen on here! well done!
9 years ago on Step 6
Ingenious! And funny too! Love it! I miss cross country bike trekking.
Great idea!! Here in Brazil we have panniers, but the prices are ridiculous. I'll certainly do that with some old backpacks!
Great inspiration!
Thanks for sharing..
Brilliant! simple..cheap........quirky....effective.......
great instructable! but what about rain? and the bin on the top, did you use it for storing most needed stuff or..what? did you by any chance wrap it up or covered with something?
the kids' bags I chose seemed to be water resistant and not just made out of cotton or canvas (the kids' bags with characters printed on them usually have some plastic or poly component to them). The bags I made for my friend were canvas and may have been a different story if they had experienced a rainstorm. I was mostly riding in the desert and only got caught in maybe one rainstorm in the Sacred Valley. Nothing in there was ever soaked, and in the plastic front pockets (before they acquired holes) everything seemed to stay dry. I had an extra 36L pack that I could sort of fit in the bin instead of on my back or a dry bag that fit perfectly, The idea was that the bin could store extra, loose items as well, but I eventually got rid of it and went the old bicycle tourer route of just strapping things on top of the rack. Bins are great for transporting small items, though, and I didn't have to worry about my bags shifting loose off the rack on dirt roads in the mountains (I was basically mountain biking with these things, and the bin allowed for me to distribute weight better). Hope that answers your questions!
very smart indeed. thanks for sharing!
I suppose you could use a couple more carabiners to attach the backpacks directly to the racks and make it easier to take them off. Great idea, nice and simple. This is the kind of thing that got me hooked on this website.
9 years ago
Wow super cool you can even take the backpacks with you
Kudos! jury rigging improvised solutions while bike touring makes for great memories too.
great idea...
9 years ago
This is really a great job. Very resourcefull.
Very clever. I would guess that this setup also discouraged theft, given the homespun appearance and the lack of expensive panniers. I'll keep this in mind when I finally get around to biking through Central America...
9 years ago
Now that is what I am talking about. It would be nice if you could show the bag attached to the clothes rack from the back. This is exactly what an ibble is supposed to be.
I added 2 additional images to show how to attach the bookbag to the pannier frame. Luckily the bike made it back from Peru in one piece so I still have it (it was lost for a few hours in the airport), Hope that helps! :)
9 years ago
good explained
Awesome job, and great concept!
