Bike Repair Stand Using a Pallet
Intro: Bike Repair Stand Using a Pallet
This is how to make your own bike repair stand for under $40.
STEP 1: Mount Flange
Screw your flange down to the pallet. Mount in the middle of one of the outer boards.
STEP 2: Screw Together the Pipe
Assemble this upsidedown L out of the pipe. Make sure to tighten all the pipe as much as possible so your stand will be more secure.
STEP 3: Cut Your Board and Drill Seat-post Hole
Cut the 1 x 2 board in two 2.5 in sections. Then clamp them together and drill a hole ( the size will depend on the diameter of your bike's seat-post) through them. Once you've drilled your hole, epoxy one side of you clamp to one piece of wood and do the same with the other.
STEP 4: Put the Clamps On
Slide the jockeying part of the clamp on, then screw the outer tightening part on.
12 Comments
trfcstu 4 years ago
i have a heavy e-bike [28kg] and was wondering if i should use thicker tubing to compensate the weight
jantiemen 4 years ago
But 4 screws in the base are not going to hold it when I get angry eh serious with my bike.... Needs bolts through the wood block.
And I would put a sheet of old plywood on top as a deck. Less trippin'
And maybe on old magnet on the horizontal pipe to hold the nuts and bolts I take off the bike.
And.... too many ideas!
Good job!
TimF10 4 years ago
TimF10 4 years ago
If you need to lower the center of gravity, cover the holes in the rim and fill it with concrete. Or you could use a 5 gallon bucket with some concrete in it as the base.
mikcal100 4 years ago
MurrayThessman 4 years ago
Leegp 4 years ago
instructur 4 years ago
pgs070947 4 years ago
Can you still turn the pedals? (For gear adjustments etc.)
deltafour 4 years ago
WeTeachThemSTEM 4 years ago
