Bongos for Stepmania/simon Game
Introduction: Bongos for Stepmania/simon Game
About: Appreciate what you've got, every day will bring something new.
This is an input device for games such as stepmania but for people who are unable to stand/use their feet. They're not strickly a musical instrument, they only detect hits and not pressure.
In the future I plan to incorporate stand alone simon hardware such as makezine's pcb and put el-wire in to the drum face
Step 1: Drum Base
I'm not sure what the proper name is for these parts, I found them in the pvc piping area of the hardware store. The smaller part fits perfectly inside the larger part, allowing me to present the switch near the face of the drum.
Step 2: Drum Face
Contact cemented a 1/4" thick circle piece of plastic/mdf which is cut slightly larger than the inner pvc part holding the switch. The idea being that the switch sit just a little taller than the inner pvc. When the drum is hit it comes down on the switch which makes contact, but then the inner pvc part stops the drum face comeing down any further, preventing wear/damage to the switch.
Step 3: Attaching the Face to the Base
Step 4: Wire Drums Together
Be the First to Share
    • For the Home Contest
    • Game Design: Student Design Challenge
    • Make It Bridge
      Make It Bridge
    4 Comments
    kumars1111
    kumars1111
    5 years ago
    Very Impressive!!
    FrostEnergy
    FrostEnergy
    14 years ago on Introduction
    this is a good idea, but the instructable is lacking a lot of detail, there are no measurements...
    anakuron
    anakuron
    15 years ago on Introduction
    For controller like this I think you choose the wrong switches, piezos would be really cool, also you could use this for drum rhythmgames also, but the cons are that you need to do a lot of (extra) work to make your controller to undestand them. Anyway It would be wise to use microswitches, same kind what are used in pop'n music controller, altough they make awfull noise, maybe you could just build your own swiches similar to dancepad... But In the end this project was really actually successful, I got lot of ideas what kind of controller I want to make for stepmania, thanks.
    Tomunist
    Tomunist
    I've been wishing I had something like this for Stepmania for a very long time. I wish there was more detail on the pieces used, including the electronic components. This would be really fun to make if I knew more about what you did.
