Bottle Cap Drink Coaster
13,484
382
17
Introduction: Bottle Cap Drink Coaster
About: Graduated from Eastern Michigan University with a bachelors in biology and chemistry and a minor in accounting. Licensed dentist in the state of Michigan. I enjoy rock music and playing the guitar, crafting, a…
This tutorial will show you how to make decorative bottle cap coasters with an epoxy resin (liquid glass) coating. These make great gifts as well as beautiful home decorations especially for a bar.
Some of the images in this tutorial will be drawings as I was not able to take pictures during some parts of the process.
Step 1: Obtain Your Wood, Cut, and Router
For my coasters, I used 0.75'' thick pine boards and cut the coasters to 4.25'' by 4.25'' squares. This allows a nice wood border if you prefer and also allows you to use any 9 bottle caps of your choosing.
Once the wood is cut, use a plunge base router with a straight router bit to router out a square in which the bottle caps will reside. I routed out an area that was 0.5'' deep.
In order to determine a nice path for the router, place the caps on top of your square piece of wood and then use a pencil to trace an approximate rounded square around the caps. Set the depth of your plunge base router and then begin to remove wood from within the area you traced.
See the first image above to see how I keep the wood stationary when using the router.
Step 2: Place Caps, Adjust, and Seal the Wood
Place your desired caps into the routed area of the coaster to see how they sit. If they are not fitting nicely together, use your router to adjust the edge so as to allow all of the bottle caps to fit nicely inside.
Next, apply some type of sealer all over the freshly cut and routed coaster before doing anything else. I like to use the gloss spar varnish from ACE hardware (see above). I would suggest applying about 3 to 4 coats. Make sure the area where you routed is coated well as this will prevent the release of bubbles when you pour the epoxy resin (liquid glass).
Step 3: Level the Coaster, Pour Some Resin, and Place Caps In
Obtain some epoxy resin. I like Rust-Oleum Parks 1-qt. Gloss Super Glaze Finish and Preservative from the Home Depot (see above).
Before pouring the resin, be sure to wrap the edges of the coaster in 1 to 2 layers of masking tape. This allows you to remove excess resin before the resin completely cures.
In addition place the coasters on a small piece of wood so that they are slightly raised above the surface (See diagram above).
BE SURE that the surface is level before pouring. This allows for the formation of a smooth level surface on the top of the coaster. The resin will self level once it is poured hence the need for a level surface.
Following the directions for the epoxy resin, pour about 1/16'' or just enough that won't flood over the top of the caps. Then take your caps and place them into the freshly poured resin. Allow this to harden and then pour another coat. Make sure to pour so some drips over the edges of the coaster. Again the resin will self-level and the resin along the edges of the coaster can be removed by peeling the tape off.
It helps to use some type of spreader. I like to save old gift cards and hotel room keys. You can use these to help move the resin.
Sorry for the absence of any pictures or videos for the pouring process. I will have to take/make a vid for this part.
Step 4: Cover Your Freshly Poured Coaster (or Coasters)
Find a box or construct/use something to place over your freshly poured coasters. This will help to prevent dust from settling on top of the resin surface while it is curing. I use cardboard boxes and have not had any problems. Make sure to place a note on top of the box saying DO NOT REMOVE or DO NOT DISTURB just in case. You worked hard to make these!
I hope you enjoyed this instructable. I am sorry for the lack of real-time photos and videos. I will try to add them as I make more in the future
Crafting 101
Crafting 101
1 Person Made This Project!
  • Big and Small Contest
  • For the Home Contest
  • Make It Bridge
    Make It Bridge
17 Comments
Wood_and_Beer
Wood_and_Beer
7 years ago
Cool!!!! Love it! Cheers ?
Schaf77
Schaf77
Reply 7 years ago
Thank you!
Graeme_P
Graeme_P
7 years ago
Very nice! How do you get such perfect looking bottle caps?
Schaf77
Schaf77
Reply 7 years ago
Many of those caps are from twist off bottles. If they are not twist off caps, when taking them off a bottle, lift a little of the cap edge around the entire cap little by little with the bottle cap opener when you are removing the cap.
njreyn
njreyn
If you're familiar with the "I don't have a bottle opener now what do I do?" method of opening (e.g. placing a bic lighter or a knife handle or something against the base of your thumb and prying from under the edge) the caps usually end up in near-pristine condition. I've been saving caps for a mosaic project, which at some point I'll get off my lazy hind end and get done. I might even post pictures!
CraigRJess
CraigRJess
Nice work! Let see some with pennies :~)
If I may add a few tips my experience with resin:
If you ARE filling the bottle caps with glue = you CAN do one big pour.
If you are NOT filling the bottle caps with glue, then yes = do it in steps.
Also, during mixing put resin in a heat bath of hot water to make it less viscous = easier pouring. Also, warm your work with hairdryer just before pouring as well.
You must be careful putting very hot drinks onto epoxy resin = it will melt or soften it enough to ruin the shape.
CristinaC3
CristinaC3
7 years ago
Cool project! What tools did u use for cutting the wood?
Schaf77
Schaf77
Thank you. I cut the wood into the squares using a compound miter saw and route the inside (where the caps lay) using a plunge base router.
Gl0ckage
Gl0ckage
7 years ago
Last few instructions I find are not clear enough. Some extra pictures would be amazing.
Schaf77
Schaf77
Yes, sorry about that. I will have to work on adding some. Stay tuned please...
Gl0ckage
Gl0ckage
7 years ago
Also what router would I be looking for? I'd like to make these however I don't have any wood tools I have limited space seen a few online but they don't seem like they can produce an effect like the one used here.
Schaf77
Schaf77
The router I use is the Dewalt 2-1/4 HP Electronic Variable Speed Fixed Base and Pluge Router Combo Kit with Soft Start
Here is the link on Home Depot's website: http://www.homedepot.com/p/DEWALT-2-1-4-HP-Electro...
I also bought a case of router bits from amazon. You can find varying lower priced bit collections for sale on Amazon, which I did and they have been working fine. This Dewalt router is a beast and I love it. Really the only tools you would need for these are the router, a saw (unless you can buy the wood pre-cut), and sandpaper.
jackowens
jackowens
7 years ago
Wow great idea!
Schaf77
Schaf77
Reply 7 years ago
Thank you!
