Introduction: Brain Tumor Identification on Brainy Pi
Brain Tumor Identification using CNN aims to use a convolutional neural network model to detect tumors in brain MRI images. Using this model, a new brain MRI image can be analyzed to find out if it has a tumor.
In this project, we implemented a brain tumor identification model on Brainy Pi.
Since this project exploits two different models for a classification task (the VGG16 model and the MobileNetV2 model), results can be reported more confidently. This is because each model serves as a second opinion on the predictions made by the other. In the case of brain MRI images where both models report the same (either tumorous or non-tumorous) observation, it becomes more compelling to believe. On the other hand, in a few instances where the models disagree, additional opinions can be obtained from domain experts before any final conclusion is reached. This makes the project versatile and fit for actual use to classify Brain MRI images as tumorous or non-tumorous.
- Brainy Pi
- UNIX OS Terminal
Step 1: Remote Connection to Brainy Pi
Log in to a remote Brainy Pi: In the Terminal or Command Prompt, use the following command to initiate the SSH connection:
ssh -X pi@auth.iotiot.in -p 65530
After establishing the connection, enter the password when prompted. Type "yes" to continue.
Once the correct password has been entered, a connection to the remote Brainy Pi's command-line interface is established.
Step 2: Cloning the Git Repository
Next is to clone the project's repository:
git clone https://gitlab.iotiot.in/interns-projects/brain-tumor-identification.git
Navigate to the project's directory using the command:
cd jay-patankar/brain-tumor-identification/demo
Step 3: Run Model Inference Program
In the directory where the Inference.py file is located, run the following command:
python3 Inference.py
Finally, the output is the result of model inference to identify whether there is a brain tumor or not.
Note: Install dependencies: Install any additional dependencies or libraries required by the application on the Brainy Pi.
