Introduction: Burlap Fourth of July Wreath
This will be the finished burlap wreath base. 24" X 24" 4 "
Step 1: Step 2: Materials You Will Need
Materials you will need:
16” wired wreath form that has three inner rings and divided into eight sections
5 ½” burlap rolls in the three colors you want to use
Fine gage wire strips, you will only need two
Scissors
Wire Cutters
Mat optional
Step 2: Step 3: Pinching the Burlap
Take about a 5 ½” of wire and pinch the burlap end together,
run the wire through the burlap.
Step 3: Step 4: Attaching to the Wreath Base
Attach the wired burlap to the bottom, top or side of your
wreath form.
Step 4: Step 5: Pulling Your Loop Through
Start
at the top or bottom of the wreath form and pull burlap up into a loop about four inches. Then twist the burlap and pull up the middle bar of the wreath form. Twist again and pull through the bottom of the wreath form, now twist and start over at the top again.
Step 5:
Do
this until you have placed four rows of loops on one section. I am choosing to put two sections of two colors and four sections of the red.
Step 6: Step 7: Ending the First Color and Starting the Second.
To change colors you first take the color you have just finished and cut about four inches away from you last loop.
Step 7:
. Then pull the four inches through the bottom wire part of the wreath form, it will stay in place for you. Now repeat with your new color as you did with the first. You will do this until the wreath form is covered in all of your burlap.
5 years ago
If you would like to see more of my creations please visit
reecewreathandcraftsetsy.com
